Full Version: mkv playback issue on XBMC
Hi all,
Just installed the latest version of XBMC as I wanted to move from WMC and I have a strange playback issue that effects some not all of the mkv files I have.
On some the playback is choppy in that it staggers slightly as if playing catchup. This is most noticible on big panaramas but is also very noticble during other scenes. Sound is unaffected...
This issue is not present in MCE (used in conjuntion with the shark 007 codecs).
I have tried numerous different settings in the video options to try and remove this issue but to no avail. I have completely removed the Shark codecs from my system aswell to rule out conflicts.
Weird how its only affecting some mkv files....
Any ideas?
Settings > Video > playback
Try these:
Enable DXVA2.
Enable Sync Playback to display (Video clock (Resample Audio)).
Enable Adjust display refresh rate to match video.
What TV are you using? Check settings on the TV.
