2011-01-07, 19:04
I wasn't sure where to post this as I a have a few nooby questions that cover a few areas (hardware, OS, and plugins) so here goes;
I have decided to go for an Acer Revo R3700, they are within budget and have all the connectors I need (HDMI & Optical).
I can't make my mind up whether to go for a Revo with no OS (and use XBMC Live) or choose one with Win 7. The difference is £80 which could go towards my much needed NAS (initially I will be playing media from a USB HDD).
I will want to;
Use my Logitech Harmony One as the main control (using the keyboard and mouse as little as possible). I take it I just need to order an IR receiver?
Play Blu Ray Rips in .iso format. Movie only rip (no need for menus), 1080p, original bitrate.
Play sopcast football streams, I know I can use the application within Windows but from searching these boards there doesn't seem to be a working plugin for XBMC.
Play FLAC music files.
I have never used Linux before but I wouldn't mind using it if it mean't the unit will do all the above (and save me some money).
Which would you recommend for me? and will the R3700 handle all of the above? or could I get something cheaper?
Any help is appreciated.
I will want to;
