2011-01-07, 20:55
I just installed xbmc a few months ago and use it to view all of my movies.
I've had a couple of handbrake movie rips fail silently--that is, the movie runs fine the first 45 minutes, and then stops because the file is incomplete. I had this happen to me twice in the last month, which is very frustrating (and embarrassing) if you want to see the end of a movie.
So, I wanted to check my video library (+1000 files) without having to play each file to the end. I wrote a small python script to automate this process for me.
This very short script requires mplayer (to calculate runtimes) and IMDbPY (a python module API for IMDb, http://imdbpy.sourceforge.net/). I wrote it on Linux, but it *might* work on other OSes if you change the location of the mplayer executable in the script.
I was able to search my entire collection (m4v and mkv files) with this command (on Linux):
The output for each movie looks like this:
The IMDb matches were not always perfect (the script searches IMDb based on the filename), but most were good enough.
This could probably be integrated into an xbmc script for a better presentation (things like flagging a file if the times differed significantly, etc.), but I haven't had the time to study the xbmc API for doing this.
(anyone with more knowledge than I have is welcome to it)
Maybe this is not a problem for many people, but this script helped me immensely and I wanted to share it. Let me know if it's useful.
Enjoy!
#!/usr/bin/env python
# cklength.py
# count_zero 2011
# This free software is licensed under the GPL (http://www.gnu.org/licenses/gpl.html)
# Check encoded movie length, compare it to feature length using IMDb
# Requires mplayer and IMDbPY to run
import sys
import os
import re
import subprocess
import os.path
import imdb
# Change this to your mplayer executable.
mplayer_exe = '/usr/bin/mplayer'
def get_feature_length(myfile):
""" Check IMDb for the movie, search based on the filename.
Will return the runtime of the first movie found, in minutes."""
name = os.path.basename(myfile).split('.')[0]
i = imdb.IMDb()
try:
m = i.search_movie(name)[0]
i.update(m)
runtime = m['runtimes'][0]
title = m['title']
return name, title, runtime
except:
return name, 'not found', 'unknown'
def get_encoded_length(myfile):
""" Use mplayer to calculate the length of the movie file.
Will return the runtime, in minutes."""
abs_myfile = os.path.abspath(myfile)
try:
command = '%s -identify -frames 0 -vc null -vo null -ao null "%s"' % (mplayer_exe, abs_myfile)
length_re = re.compile('ID_LENGTH=.*')
p = subprocess.Popen(command, shell=True, stdout=subprocess.PIPE, stderr=subprocess.STDOUT)
length = p.communicate()[0]
mylength = int(length_re.findall(length)[0].lstrip('ID_LENGTH=').split('.')[0]) / 60
return mylength
except:
return 'unknown'
if __name__ == "__main__":
myfiles = sys.argv[1:]
for myfile in myfiles:
length = get_encoded_length(myfile)
name, title, runtime = get_feature_length(myfile)
print '%s (IMDb name: %s) - %s min (local) / %s min (IMDb)' % (myfile, title, length, runtime)
find . \( -iname \*m4v -o -iname \*mkv \) -exec cklength.py '{}' \; > movie_runtimes.txt
Action/Bourne Ultimatum.m4v (IMDb name: The Bourne Ultimatum) - 115 min (local) / 115 min (IMDb)
Enjoy!
