unlike other skins a cannot enter a view type selction window by pressing a certain arrow key. I do have enabled the possible viewtypes in the settings arrea.
Can anyone help me how to chance the type of view in MOVIE library mode?
Thanx in advance!
Pressing UP or LEFT, depending on your viewtype, should get you to the menu. By default AeonMQ only has 2 view options activated, there is a menu option to activate more views in the left menu. You can also get to it through the Aeon settings.
Jay_M Wrote:Pressing UP or LEFT, depending on your viewtype, should get you to the menu. By default AeonMQ only has 2 view options activated, there is a menu option to activate more views in the left menu. You can also get to it through the Aeon settings.
Well indeed I thought so but no options will appear when doing that for changing the view type....So this is the problem I think...
help is trully welcome
Update: Also reinstalled the skin...but no succes!
Make sure you don't have "kiosk" mode selected. It is in Settings -> Advanced?
Jay_M Wrote:Make sure you don't have "kiosk" mode selected. It is in Settings -> Advanced?
You are My hero Jay!!!!
No prob. Just glad to give back.
my thanks also. I'm new to XBMC and this was driving me mad
I'm looking at a lovely wall right now and it looks good
Are there any other view types for TV shows. There only seems to be one available (i am not in kiosk mode)
