Hello,
I recently isntalled the newest flavor of xbmc on both my mac laptop and windows 7 x64 desktop...with media companion i downloaded all the episode information etc...which put those files in the directories of the shows and movies...once all that was downloaded i then told xbmc where the tv libraries and movie libraries are (both NAS)...on the mac everything works like a charm, loads up shows me new shows etc...but on the windows machine it seems to choke and crash once i go to browse any show
the reason for the title of episode limit is i have over 190 shows archived which amounts to 13,000+ episodes.
Holy frickin run on sentence.
People here like to help. Try and make it as easy as possible.
Wanna try again in English?
FishOil Wrote:Holy frickin run on sentence.
I understood his question fine. He has a huge library of TV Shows that work fine on his Mac, but do not work when he tries to watch them on his Windows Machine. He's asking if XBMC has a limit to the number of shows when running on a Windows box.
I personally don't know the answer, but I'm sure as heck not going to be a jerk about the way someone asks a question. I'd appreciate it if you would do the same.
imtammer, I hope you find an answer.
imtammer Wrote:Hello,
No limit that I know of. How about enabling debug, recreating the issue that causes the crash and then posting the resulting log file.
Except you.
Last time I checked ellipsis was a form of punctuation, not proper, but definitely keeps it from being a typical run-on sentence.
DurhamDev Wrote:I understood his question fine. He has a huge library of TV Shows that work fine on his Mac, but do not work when he tries to watch them on his Windows Machine. He's asking if XBMC has a limit to the number of shows when running on a Windows box.
Note FishOils' reputation - this is is m.o. - post a snide remark and be of little help.
imtammer - post the debug log and it should be pretty easy to troubleshoot.
imtammer, ditto what stoli said. Also, if you need help figuring out how to post a debug log, check my signature and click the link on how to post windows problems.
thankyou for all the help despite FishOil's troll-ish response.
Nate, I was following the instructions on your sig-link to get the debug log, however when i go to click settings it crashes again. I will continue to try, however should i be doing something else instead?
Log Name: Application
Source: Application Error
Date: 1/7/2011 5:45:26 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: NoName-PC
Description:
Faulting application name: XBMC.exe, version: 10.0.0.0, time stamp: 0x4d0ba15b
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x0031002d
Faulting process id: 0xa94
Faulting application start time: 0x01cbaed57e16beb0
Faulting application path: C:\Program Files (x86)\XBMC\XBMC.exe
Faulting module path: unknown
Report Id: f6ea2bb0-1ac8-11e0-ad24-bcaec504f29b
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2011-01-08T01:45:26.000000000Z" />
<EventRecordID>26607</EventRecordID>
<Channel>Application</Channel>
<Computer>NoName-PC</Computer>
<Security />
</System>
<EventData>
<Data>XBMC.exe</Data>
<Data>10.0.0.0</Data>
<Data>4d0ba15b</Data>
<Data>unknown</Data>
<Data>0.0.0.0</Data>
<Data>00000000</Data>
<Data>c0000005</Data>
<Data>0031002d</Data>
<Data>a94</Data>
<Data>01cbaed57e16beb0</Data>
<Data>C:\Program Files (x86)\XBMC\XBMC.exe</Data>
<Data>f6ea2bb0-1ac8-11e0-ad24-bcaec504f29b</Data>
</EventData>
</Event>
and the last 3 lines of xbmc.log are:
17:45:17 T:2264 M:2065833984 ERROR: exception in CApplication::FrameMove()
17:45:26 T:2264 M:2084159488 ERROR: Previous line repeats 11 times.
17:45:26 T:2264 M:2084159488 ERROR: CApplication::FrameMove(), too many exceptions
there are rar errors as well right above those lines:
17:45:06 T:7036 M:2065051648 ERROR: XFILE::CDirectory::GetDirectory - Error getting rar://smb%3a%2f%2farchive%2fvideo%2fTV%2fBoston%20Legal%2fSeason%203%2fwrx%2dshik%2epart10%2erar/
17:45:07 T:7036 M:2065379328 ERROR: XFILE::CDirectory::GetDirectory - Error getting rar://smb%3a%2f%2farchive%2fvideo%2fTV%2fBoston%20Legal%2fSeason%203%2fwrx%2dshik%2epart13%2erar/
It looks like you may have some corrupt files? Have you tried moving those Boston Legal files outside the scanned directory and seeing if that fixes the issue?
Another guess is the path may be too long for the rar files. Try blacklist's suggestion and scan again. This time paste your entire log file to pastebin.com and then post the url after you have submitted that.
i can assure you i have directories with far longer paths....monty pythons flying circus springs to mind, and it hasnt an issue with those...the other strange thing is the mac has NO issue with any of these, be it path issues or rar module issues.
either way here is the pastebin log link:
http://pastebin.com/2g745we7
Doesn't look like debug was enabled, but it also doesn't look like that machine likes your paths:
Error getting smb://KHEMT/Videos/Public/TV/Boston Legal/
Error getting rar://smb%3a%2f%2farchive%2fvideo%2fT.......
the end of the log is filled with those errors.
