i know i know. but i've read all the posts i can stand. specs..
xbox 1.4
xenium ice 2.0.1 (latest i think)
xbmc 1_1 think it was a december build.
static ip with all correct dns/gateway.
apple works, shoutcast 500 in music works.
all other functions seem to work as well.
damn kml browser (webradio button) doesn't.
i have replaced url for kiss radio in kmlbrowse.py from posts.
here is the pertinent log from xbmc...
07-01-2002 10:54:15 info traceback (most recent call last):
07-01-2002 10:54:15 info file "q:\scripts\kmlbrowse.py", line 23, in ?
07-01-2002 10:54:15 info import xbmc, xbmcgui, image
07-01-2002 10:54:15 info systemerror
07-01-2002 10:54:15 info :
07-01-2002 10:54:15 info null result without error in pyobject_call
i don't think i am missing any python files or apple and shoucast 500 wouldn't work, right?
shoutcast is pretty good but i would prefer kml like from v1.0 xbmc. thanks
also tried simplekml.py from posts here with the following similiar results....launcing with scripts menu....
07-01-2002 11:37:27 info traceback (most recent call last):
07-01-2002 11:37:27 info file "q:\scripts\simplekml.py", line 23, in ?
07-01-2002 11:37:27 info import xbmc, xbmcgui, image
07-01-2002 11:37:27 info systemerror
07-01-2002 11:37:27 info :
07-01-2002 11:37:27 info null result without error in pyobject_call
if your shoutcast 500 and apple work does not mean that you have all the necessary python libs for webradio.
make sure you have the correct python libs.
what is your list of python libs? do you have the image libs that are needed? please provide more details.
also, maybe you need to set your date/time correctly for your xbox. you do know it is 2005 and not 2002 right?
ts
there is a python23.zlib file in the python folder. it's about 3 megs. it contains tons of .py files and folders. it came this way from the build i have. i have checked what i have (unzipped) aside from this file against other kmlbrowse.rar packages i found around and my folder seems to be complete. i hate to trash up my python directory if these files are unnecessary. so from the log does it mean it's having trouble importing items that are missing? i'll see if i can post my unzipped files from python folder here next.
yeah i saw the date was incorrect but didn't think this was an issue. i'll try and reset that first and see what happens.
thanks.
set date and time...still same problem.
i didn't really say what it was doing but when i choose webradio or manually run simplekml script it flashes real fast (running) but then exits.
ok here is my filelist from python directory. i can also paste the contents of python23.zlib but it's huge. i hope this post comes out ok.
2005-01-08 02:21 folder folder python
2005-01-08 02:21 10896 10896 python\gifimageplugin.py
2005-01-08 02:21 9011 9011 python\gifimageplugin.pyo
2005-01-08 02:21 54748 54748 python\image.py
2005-01-08 02:21 36442 36442 python\image.pyo
2005-01-08 02:21 11810 11810 python\imagefile.py
2005-01-08 02:21 10521 10521 python\imagefile.pyo
2005-01-08 02:21 4549 4549 python\imagepalette.py
2005-01-08 02:21 5239 5239 python\imagepalette.pyo
2005-01-08 02:21 12907 12907 python\jpegimageplugin.py
2005-01-08 02:21 12625 12625 python\jpegimageplugin.pyo
2005-01-08 02:21 folder folder python\lib
2005-01-08 02:21 10896 10896 python\lib\gifimageplugin.py
python\lib\image.py
python\lib\imagefile.py
2005-01-08 02:21 4549 4549 python\lib\imagepalette.py
2005-01-08 02:21 12907 12907 python\lib\jpegimageplugin.py
2005-01-08 02:21 135228 135228 python\lib\pyexpat.pyd
2005-01-08 02:21 405504 405504 python\lib\unicodedata.pyd
2005-01-08 02:21 61497 61497 python\lib\zlib.pyd
2005-01-08 02:21 57401 57401 python\lib\_sre.pyd
2005-01-08 02:21 495616 495616 python\lib\_ssl.pyd
2005-01-08 02:21 20480 20480 python\lib\_symtable.pyd
2005-01-08 02:21 2971357 2971357 python\python23.zlib
# archive python\python23.zlib
*************************omitted items within archive
# end of archive
2005-01-08 02:21 491 491 python\readme.txt
2005-01-08 02:21 folder folder python\spyce
2005-01-08 02:21 18295 18295 python\spyce\changes
2005-01-08 02:21 26270 26270 python\spyce\cookie.py
2005-01-08 02:21 9374 9374 python\spyce\fcgi.py
2005-01-08 02:21 4877 4877 python\spyce\installhelper.py
2005-01-08 02:21 2182 2182 python\spyce\licence
2005-01-08 02:21 5796 5796 python\spyce\makefile
2005-01-08 02:21 folder folder python\spyce\modules
2005-01-08 02:21 2780 2780 python\spyce\modules\automaton.py
2005-01-08 02:21 2617 2617 python\spyce\modules\compress.py
2005-01-08 02:21 1771 1771 python\spyce\modules\cookie.py
2005-01-08 02:21 5940 5940 python\spyce\modules\error.py
2005-01-08 02:21 4066 4066 python\spyce\modules\include.py
2005-01-08 02:21 1642 1642 python\spyce\modules\pool.py
2005-01-08 02:21 2489 2489 python\spyce\modules\redirect.py
2005-01-08 02:21 7243 7243 python\spyce\modules\request.py
2005-01-08 02:21 6364 6364 python\spyce\modules\response.py
2005-01-08 02:21 11881 11881 python\spyce\modules\session.py
2005-01-08 02:21 1899 1899 python\spyce\modules\spylambda.py
2005-01-08 02:21 3669 3669 python\spyce\modules\stdout.py
2005-01-08 02:21 3057 3057 python\spyce\modules\taglib.py
2005-01-08 02:21 2372 2372 python\spyce\modules\template.py
2005-01-08 02:21 7265 7265 python\spyce\modules\toc.py
2005-01-08 02:21 6718 6718 python\spyce\modules\transform.py
2005-01-08 02:21 429 429 python\spyce\readme
2005-01-08 02:21 664 664 python\spyce\release
2005-01-08 02:21 650 650 python\spyce\run_spycecgi.py
2005-01-08 02:21 652 652 python\spyce\run_spycecmd.py
2005-01-08 02:21 1569 1569 python\spyce\run_spycemodpy.py
2005-01-08 02:21 4226 4226 python\spyce\spyce.conf
2005-01-08 02:21 13504 13504 python\spyce\spyce.mime
2005-01-08 02:21 7097 7097 python\spyce\spyce.nsi
2005-01-08 02:21 7112 7112 python\spyce\spyce.nsi.in
2005-01-08 02:21 22666 22666 python\spyce\spyce.py
2005-01-08 02:21 2483 2483 python\spyce\spyce.spec.in
2005-01-08 02:21 2498 2498 python\spyce\spyceapache.conf
2005-01-08 02:21 4183 4183 python\spyce\spycecache.py
2005-01-08 02:21 1271 1271 python\spyce\spycecgi.py
2005-01-08 02:21 11674 11674 python\spyce\spycecmd.py
2005-01-08 02:21 39208 39208 python\spyce\spycecompile.py
2005-01-08 02:21 13606 13606 python\spyce\spyceconfig.py
2005-01-08 02:21 3846 3846 python\spyce\spyceexception.py
2005-01-08 02:21 3249 3249 python\spyce\spycelock.py
2005-01-08 02:21 4162 4162 python\spyce\spycemodpy.py
2005-01-08 02:21 1643 1643 python\spyce\spycemodule.py
2005-01-08 02:21 7697 7697 python\spyce\spycetag.py
2005-01-08 02:21 5350 5350 python\spyce\spyceutil.py
2005-01-08 02:21 10037 10037 python\spyce\spycewww.py
2005-01-08 02:21 813 813 python\spyce\spycexbmc.py
2005-01-08 02:21 folder folder python\spyce\tags
2005-01-08 02:21 3156 3156 python\spyce\tags\core.py
2005-01-08 02:21 1665 1665 python\spyce\thanks
2005-01-08 02:21 1692 1692 python\spyce\tree.py
2005-01-08 02:21 1012 1012 python\spyce\verchk.py
2005-01-08 02:21 folder folder python\temp
# total size packed files
# 4727613 4727613 80
i see image.py but should i see also the other files from import line like xbmc and xbmcgui?
what about clearing out face008 or erasing db files?
your python directory is messed up.
all the image python files should be in python/lib directory, not in the python dir.
ex:
my python/lib dir:
ncftp /e/apps/xbmc/python/lib > ls -al
-rw-r--r-- 1 ftp ftp 6630 jun 06 21:08 bmpimageplugin.py
-rw-r--r-- 1 ftp ftp 6446 nov 05 08:34 bmpimageplugin.pyo
-rw-r--r-- 1 ftp ftp 10896 jun 18 23:12 gifimageplugin.py
-rw-r--r-- 1 ftp ftp 9011 nov 05 08:34 gifimageplugin.pyo
-rw-r--r-- 1 ftp ftp 54748 jun 18 23:12 image.py
-rw-r--r-- 1 ftp ftp 36442 nov 05 08:34 image.pyo
-rw-r--r-- 1 ftp ftp 11810 jun 18 23:12 imagefile.py
-rw-r--r-- 1 ftp ftp 10521 nov 05 08:34 imagefile.pyo
-rw-r--r-- 1 ftp ftp 4549 jun 18 23:12 imagepalette.py
-rw-r--r-- 1 ftp ftp 5239 nov 05 08:34 imagepalette.pyo
-rw-r--r-- 1 ftp ftp 12907 jun 18 23:12 jpegimageplugin.py
-rw-r--r-- 1 ftp ftp 12625 nov 05 08:34 jpegimageplugin.pyo
-rw-r--r-- 1 ftp ftp 1864 jun 06 21:08 mpegimageplugin.py
-rw-r--r-- 1 ftp ftp 2661 dec 03 20:39 mpegimageplugin.pyo
-rw-r--r-- 1 ftp ftp 405504 jan 04 20:21 unicodedata.pyd
-rw-r--r-- 1 ftp ftp 57401 jan 04 20:21 _sre.pyd
-rw-r--r-- 1 ftp ftp 495616 jan 04 20:21 _ssl.pyd
-rw-r--r-- 1 ftp ftp 20480 jan 04 20:21 _symtable.pyd
-rw-r--r-- 1 ftp ftp 135228 jan 04 20:21 pyexpat.pyd
-rw-r--r-- 1 ftp ftp 61497 jan 04 20:21 zlib.pyd
it should work once you fix that.
ts
got it. did 2 things and not sure whick one fixed it. i simply recopied my files over using evox ftp and also since i had access to x,y,z i deleted all files in x (saved first and y and z were empty). so either one of my files were corrupted from earlier ftp transfer or had bad info in cache x drive. i assume the earlier. thanks.
