Full Version: Success: Cheap Wireless-Remote via Lirc
Using XBMC in the version that was installed with Ubuntu 10.10...
Yesterday my wireless remote arrived ...
http://www.pollin.de/shop/dt/MzIyODcyOTk...r_X10.html
This remote is sold in germany by Pollin-Elektronik. It uses a 433MHz-system for transmission. It is a medion-product, propably sold with ALDI-computers, now available for about 8 euros.
I have found many things in google, and after some hours i got the first results.
The first problem was that XBMC did not recognize any lirc, something had changed in lirc, so the startup-command for xbmc had to be changed to:
xbmc --lircdev /var/run/lirc/lircd
I changed this for the icon and the autostart-command i had inserted, then my remote was recognized by xbmc.
The second problem was that i could not get the "back"-key to work. The command bound to that key was written with two upper case characters. After hours of searching i tried to change all characters to lower case, and yes, that was the solution...
Now all functions work nearly as expected. The only thing is that when i use my normal keyboard, the "Backspace"-key works in every circumstance, the back-button of the remote does not. I can exit the fullscreen-video with the backspace-key, the video keeps on running as a mini-creen, i can scroll the filelist then. I will try to search the keyboard-xml-file for the solution of that thing.
I am writing this on my windows-computer, but will upload my lirc-configs and my xml-files when i start my mediacenter today or tomorow, so be patient Smile
I will add a list of links to some websites i have used, too ...
My config-files:
hardware.conf in /etc/lirc/
# /etc/lirc/hardware.conf
#Chosen Remote Control
REMOTE="pollinx10"
REMOTE_MODULES=""
REMOTE_DRIVER="atilibusb"
REMOTE_DEVICE=""
REMOTE_SOCKET=""
REMOTE_LIRCD_CONF="atiusb/lircd.conf.atilibusb"
REMOTE_LIRCD_ARGS=""
#Chosen IR Transmitter
TRANSMITTER="None"
TRANSMITTER_MODULES=""
TRANSMITTER_DRIVER=""
TRANSMITTER_DEVICE=""
TRANSMITTER_SOCKET=""
TRANSMITTER_LIRCD_CONF=""
TRANSMITTER_LIRCD_ARGS=""
#Enable lircd
START_LIRCD="true"
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD="false"
#Try to load appropriate kernel modules
LOAD_MODULES="true"
# Default configuration files for your hardware if any
LIRCMD_CONF=""
#Forcing noninteractive reconfiguration
#If lirc is to be reconfigured by an external application
#that doesn't have a debconf frontend available, the noninteractive
#frontend can be invoked and set to parse REMOTE and TRANSMITTER
#It will then populate all other variables without any user input
#If you would like to configure lirc via standard methods, be sure
#to leave this set to "false"
FORCE_NONINTERACTIVE_RECONFIGURATION="false"
START_LIRCMD=""
lircd.conf in /etc/lirc
# Please make this file available to others
# by sending it to <[email protected]>
# this config file was automatically generated
# using lirc-0.8.7-pre3(atilibusb) on Mon Jan 10 14:28:32 2011
# contributed by Hartmut Wagener
# brand: Pollin/Medion   /root/lircd.conf
# model no. of remote control: 40009936
# devices being controlled by this remote: Computer
begin remote
  name  pollinx10
  bits           16
  eps            30
  aeps          100
  one             0     0
  zero            0     0
  pre_data_bits   8
  pre_data       0x14
  post_data_bits  16
  post_data      0x0
  gap          40006
  min_repeat      8
  suppress_repeat 3
#  uncomment to suppress unwanted repeats
  toggle_bit_mask 0x80800000
      begin codes
          KEY_0                    0x6C97
          KEY_1                    0xE20D
          KEY_2                    0x638E
          KEY_3                    0xE40F
          KEY_4                    0x6590
          KEY_5                    0xE611
          KEY_6                    0x6792
          KEY_7                    0xE813
          KEY_8                    0x6994
          KEY_9                    0xEA15
          KEY_POWER                0xD702
          KEY_TV                   0x012C
          KEY_VIDEO                0x82AD
          KEY_CD                   0xD904
          KEY_AUDIO                0x5B86
          KEY_RADIO                0x032E
          KEY_TAPE                 0x5A85
          KEY_INFO                 0x042F
          KEY_DOCUMENTS            0x86B1
          KEY_TEXT                 0xEB16
          KEY_MENU                 0x6E99
          KEY_BACK                 0xF520
          KEY_UP                   0xCDF8
          KEY_DOWN                 0xC5F0
          KEY_SELECT               0xF01B
          KEY_ENTER                0x739E
          KEY_VOLUMEUP             0xDE09
          KEY_VOLUMEDOWN           0x5D88
          KEY_CHANNELUP            0xE00B
          KEY_CHANNELDOWN          0x618C
          KEY_MUTE                 0xD500
          KEY_REFRESH              0x719C
          KEY_RED                  0x0732
          KEY_GREEN                0x88B3
          KEY_YELLOW               0x0934
          KEY_BLUE                 0x8AB5
          KEY_STOP                 0xFD28
          KEY_PAUSE                0x7EA9
          KEY_PLAY                 0xFA25
          KEY_PREVIOUS             0x76A1
          KEY_NEXT                 0xF823
          KEY_EJECTCD              0x6D98
          KEY_REWIND               0xF924
          KEY_FASTFORWARD          0x7BA6
          KEY_RECORD               0xFC27
          KEY_LEFT                 0x729D
          KEY_RIGHT                0xF41F
      end codes
end remote
Lircmap.xml in home/.xbmc/userdata
<lircmap>
<remote device="pollinx10">
<play>KEY_PLAY</play>
<pause>KEY_PAUSE</pause>
<stop>KEY_STOP</stop>
<forward>KEY_FASTFORWARD</forward>
<reverse>KEY_REWIND</reverse>
<left>KEY_LEFT</left>
<right>KEY_RIGHT</right>
<up>KEY_UP</up>
<down>KEY_DOWN</down>
<select>KEY_SELECT</select>
<select>KEY_ENTER</select>
<pageplus>KEY_CHANNELUP</pageplus>
<pageminus>KEY_CHANNELDOWN</pageminus>
<back>KEY_BACK</back>
<menu>KEY_MENU</menu>
<title>KEY_TV</title>
<info>KEY_INFO</info>
<skipplus>KEY_NEXT</skipplus>
<skipminus>KEY_PREVIOUS</skipminus>
<display>KEY_MUTE</display>
<record>KEY_RECORD</record>
<volumeplus>KEY_VOLUMEUP</volumeplus>
<volumeminus>KEY_VOLUMEDOWN</volumeminus>
<mute>KEY_MUTE</mute>
<power>KEY_POWER</power>
<one>KEY_1</one>
<two>KEY_2</two>
<three>KEY_3</three>
<four>KEY_4</four>
<five>KEY_5</five>
<six>KEY_6</six>
<seven>KEY_7</seven>
<eight>KEY_8</eight>
<nine>KEY_9</nine>
<zero>KEY_0</zero>
<mymusic>KEY_AUDIO</mymusic>
<mypictures>KEY_TAPE</mypictures>
<myvideo>KEY_VIDEO</myvideo>
<playlist>KEY_TEXT</playlist>
<guide>KEY_DOCUMENTS</guide>
</remote>
</lircmap>
remote.xml in home/.xbmc/userdate/keymaps
      <back>parentdir</back>
