2011-01-12, 01:22
I'm trying to use voinage's narutowire plugin, it will list the anime titles, but when I click on one I hear the "this plugin failed" noise, and it freezes for awhile/forever...I have no clue why. I'm using the newest build of xbmc4xbox
Can anyone help?
111104 NOTICE: -----------------------------------------------------------------------
17:54:50 M: 56090624 NOTICE: Starting XBMC4Xbox. Built on Jan 7 2011 (SVN:30779, compiler 1310)
17:54:50 M: 56090624 NOTICE: special://xbmc/ is mapped to: Q:\
17:54:50 M: 56090624 NOTICE: special://masterprofile/ is mapped to: q:\UserData
17:54:50 M: 56090624 NOTICE: special://home/ is mapped to: Q:\
17:54:50 M: 56090624 NOTICE: special://temp/ is mapped to: Z:\
17:54:50 M: 56090624 NOTICE: The executable running is: E:\Apps\BUILD\default.xbe
17:54:50 M: 56090624 NOTICE: Log File is located: Q:\xbmc.log
17:54:50 M: 56090624 NOTICE: -----------------------------------------------------------------------
17:54:50 M: 56090624 NOTICE: Unmapped drive T
17:54:50 M: 56090624 NOTICE: Mapping drive T to Harddisk0\Partition1\Apps\BUILD\UserData
17:54:50 M: 56090624 NOTICE: Setup DirectX
17:54:50 M: 56061952 NOTICE: Mapping drive C to Harddisk0\Partition2
17:54:50 M: 56061952 NOTICE: Mapping drive E to Harddisk0\Partition1
17:54:50 M: 56061952 NOTICE: Unmapped drive D
17:54:50 M: 56061952 NOTICE: Mapping drive D to Cdrom0
17:54:50 M: 56061952 NOTICE: map extended drive F:
17:54:50 M: 56061952 NOTICE: Mapping drive F to Harddisk0\Partition6
17:54:50 M: 56061952 NOTICE: map extended drive R:
17:54:50 M: 56061952 NOTICE: Mapping drive R to Harddisk0\Partition8
17:54:50 M: 56061952 NOTICE: Mapping drive X to Harddisk0\Partition3
17:54:50 M: 56061952 NOTICE: Mapping drive Y to Harddisk0\Partition4
17:54:50 M: 56061952 NOTICE: Unmapped drive Z
17:54:50 M: 56061952 NOTICE: Mapping drive Z to Harddisk0\Partition5
17:54:50 M: 56061952 NOTICE: load settings...
17:54:50 M: 56061952 NOTICE: Mapping drive P to Harddisk0\Partition1\Apps\BUILD\UserData
17:54:50 M: 56061952 NOTICE: special://profile/ is mapped to: q:\UserData
17:54:50 M: 56061952 NOTICE: loading special://masterprofile/guisettings.xml
17:54:50 M: 55603200 NOTICE: Getting hardware information now...
17:54:50 M: 55582720 NOTICE: Checking resolution 10
17:54:50 M: 55582720 NOTICE: Setting autoresolution mode 4
17:54:50 M: 55513088 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:54:50 M: 55492608 NOTICE: Loaded playercorefactory configuration
17:54:50 M: 55472128 NOTICE: Loading player core factory settings from special://profile/playercorefactory.xml.
17:54:50 M: 55472128 NOTICE: Loaded playercorefactory configuration
17:54:50 M: 55472128 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
17:54:50 M: 55472128 NOTICE: Default Video Player: dvdplayer
17:54:50 M: 55472128 NOTICE: Default Audio Player: paplayer
17:54:50 M: 55472128 NOTICE: Per AV pack settings are off
17:54:50 M: 55922688 NOTICE: q:\UserData\sources.xml
17:54:51 M: 50622464 NOTICE: Network: Using dashboard IP settings
17:54:51 M: 50290688 NOTICE: Checking the Date!
17:54:51 M: 50290688 NOTICE: start dvd mediatype detection
17:54:51 M: 50225152 NOTICE: initializing playlistplayer
17:54:51 M: 50225152 NOTICE: DONE initializing playlistplayer
17:54:51 M: 50216960 NOTICE: load default skin:[Confluence]
17:54:54 M: 43843584 NOTICE: initialize done
17:54:54 M: 43843584 NOTICE: Running the application...
17:54:54 M: 41140224 NOTICE: -->Python Initialized<--
17:54:54 M: 40611840 NOTICE: Attempting to mount memory unit device 00000005
17:54:56 M: 36970496 NOTICE: Webserver: Starting...
17:54:57 M: 36859904 NOTICE: Webserver: Started
17:54:57 M: 36859904 NOTICE: XBFileZilla: Starting...
17:54:57 M: 36794368 NOTICE: ES: Starting event server
17:54:57 M: 35725312 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
17:54:57 M: 35446784 NOTICE: UDP: Listening on port 9777
17:54:59 M: 27873280 NOTICE: XBFileZilla: Started
17:56:07 M: 33677312 ERROR: Unable to load: special://home/plugins/video/TheEscapist/resources/settings.xml, Line 0
Failed to open file
17:56:07 M: 31260672 NOTICE: -->Python Initialized<--
17:56:09 M: 28352512 NOTICE: Mode: None
17:56:09 M: 28352512 NOTICE: URL: None
17:56:09 M: 28352512 NOTICE: Name: None
17:56:09 M: 28352512 NOTICE: Start: 0
17:56:09 M: 28352512 NOTICE: categories
17:56:11 M: 32989184 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 22
17:56:11 M: 33030144 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
17:56:12 M: 33869824 ERROR: Unable to load: special://home/plugins/video/TheEscapist/resources/settings.xml, Line 0
Failed to open file
17:56:12 M: 31465472 NOTICE: -->Python Initialized<--
17:56:14 M: 28856320 NOTICE: Mode: 1
17:56:14 M: 28856320 NOTICE: URL: /0
17:56:14 M: 28856320 NOTICE: Name: Videos Feed
17:56:14 M: 28856320 NOTICE: Start: 0
17:56:42 M: 33267712 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 22
17:56:42 M: 33267712 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
17:56:47 M: 33304576 ERROR: Unable to load: special://home/plugins/video/plugin.video.tas/resources/settings.xml, Line 0
Failed to open file
17:56:48 M: 30912512 NOTICE: -->Python Initialized<--
17:56:49 M: 28295168 ERROR: Error Type: exceptions.ImportError
17:56:49 M: 28295168 ERROR: Error Contents: No module named TasAPI
17:56:49 M: 28295168 ERROR: Traceback (most recent call last):
File "Q:\plugins\video\plugin.video.tas\default.py", line 6, in ?
from TasAPI import common as common
ImportError: No module named TasAPI
17:56:50 M: 33423360 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting plugin://video/plugin.video.tas/
17:56:50 M: 33423360 ERROR: CGUIMediaWindow::GetDirectory(plugin://video/plugin.video.tas/) failed
17:57:00 M: 33124352 ERROR: Unable to load: special://home/plugins/video/Naruto Wire/resources/settings.xml, Line 0
Failed to open file
17:57:01 M: 30732288 NOTICE: -->Python Initialized<--
17:57:02 M: 28291072 NOTICE: Mode: None
17:57:02 M: 28291072 NOTICE: URL: None
17:57:02 M: 28291072 NOTICE: Name: None
17:57:02 M: 28291072 NOTICE: categories
17:57:27 M: 25931776 ERROR: Unable to load: special://home/plugins/video/Naruto Wire/resources/settings.xml, Line 0
Failed to open file
17:57:28 M: 23539712 NOTICE: -->Python Initialized<--
17:57:29 M: 20701184 NOTICE: Mode: 1
17:57:29 M: 20701184 NOTICE: URL: http://www.nwanime.com/73/air-gear
17:57:29 M: 20701184 NOTICE: Name: air-gear
17:57:29 M: 20701184 NOTICE: index of : http://www.nwanime.com/73/air-gear
17:57:30 M: 20709376 ERROR: Error Type: exceptions.IndexError
17:57:30 M: 20709376 ERROR: Error Contents: list index out of range
17:57:30 M: 20709376 ERROR: Traceback (most recent call last):
File "Q:\plugins\video\Naruto Wire\default.py", line 344, in ?
EPLIST(url)
File "Q:\plugins\video\Naruto Wire\default.py", line 21, in EPLIST
req = urllib2.Request('http://www.narutowire.com/category_detail.php?page=%s&chid=%s'%(i,Id[0]))
IndexError: list index out of range
17:57:31 M: 25780224 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting plugin://video/Naruto Wire/?url=http%3A%2F%2Fwww.nwanime.com%2F73%2Fair-gear&mode=1&name=air-gear
17:57:31 M: 25780224 ERROR: CGUIMediaWindow::GetDirectory(plugin://video/Naruto Wire/?url=http%3A%2F%2Fwww.nwanime.com%2F73%2Fair-gear&mode=1&name=air-gear) failed
