What confusing me, is greyed "Update" section in Addon Information (add-on page in settings)
How can I make it actually working & updating my addon?
Anyway, is there a good sample how I can make my addon updating? Should I create repository addon as besides main addon?
Or I can create one addon which will inclule self-update information and main addon? That would be really cool - becouse I should not ask user to install from zip repo, that go to sources and install actually addon, just to get it autoupdating.
Is there any working & simple examples of that? The wiki page about repositories did not tell me much.
Thanks in advance.
not how it works. the add-on is updated in the repository, xbmc see it, and by default autoupdates it.
works fine for me, when i remove the god damn __MACOSX folder from the zip.
omg. I feel stupid. Works great, those __MACOSX cost me a lot...
BTW, is it possiple, to have 2 entry ponts inside one file?
point="xbmc.addon.repository"
and
point="xbmc.python.pluginsource"
Like
<extension point="xbmc.python.pluginsource" provides="image, video, audio" library="default.py">
<provides>image video audio</provides>
</extension>
<extension point="xbmc.addon.repository" name="VK XBMC Add-ons">
<info compressed="false">http://xbmc-vk-repo.googlecode.com/svn/trunk/addons/addons.xml</info>
<checksum>http://xbmc-vk-repo.googlecode.com/svn/trunk/addons/addons.xml.md5</checksum>
<datadir zip="false">http://xbmc-vk-repo.googlecode.com/svn/trunk/addons/</datadir>
</extension>
you tell me
if it doesn't work, that's something we really want to support.
I fell myself getnius =)
that is the way to make plugin update itself ) isn't it really cool?
Here is working example
http://code.google.com/p/xbmc-vk-repo/so.../test_test
Trick is to
Name entry points different:
</extension>
<info compressed="false">http://xbmc-vk-repo.googlecode.com/svn/trunk/test_test/addons.xml</info>
<checksum>http://xbmc-vk-repo.googlecode.com/svn/trunk/test_test/addons.xml.md5</checksum>
<datadir zip="false">http://xbmc-vk-repo.googlecode.com/svn/trunk/test_test/</datadir>
</extension>
otherwise, you'll get superbug, (if names are same) btw
Can you confirm or test that if it is interesting for you?
and yep, it is working.
Will it still be working, or it is an unreliable way?
nice. sure, if it works it's all good
Cheers. I think this topick would be usefull for folks. Thanks!
Cheers!
So, add-on can be repository to it's own. Self Auto-Update Achieved =)
/sorry for flood, my browser does strange things, did not show prev. message/
hello
Looks interesting but I'm not sure to understand very well.
Can you give the full howto to make an addon self updatable ? Or maybe we just have to set the addon.xml like you did ?
You talked about "Name entry points different" but I'm not sure to understand what need to be different exactly.
(Sorry but as english is not my native language, sometimes i'm not sure to understant correctly !)
I did provide my plugin with everything -
Actually, you should not install plugin and repository, they are in one box. Name differently:
"name" xml property should be different for xbmc.addon.repository, otherwise, it is really working wired.
BTW. I do not have time to test it, it would be really cool if you share your experience.
Sorry I may be tired I don't understand... Will have a look tomorrow
