Full Version: .strm worked now doesnt work.
i have been looking all over the forums for an answer and no such luck. i called my friend who also loves xbmc and he doesn't get it either. this is my first post and Ive been using xbmc since at least 2007.
neway i got an .asx file that i changed into a .strm that i could launch in file mode. it randomly stopped working in xbmc but it worked in vlc.
so i called my friend and he emailed me a .strm that he created with a different url for the same stream. this .strm that he made played in vlc and xbmc at his place but it only works on vlc at my place. i checked the debug log at my place and it looks like this:
INFO: CFileCache:Tonguerocess - Hit eof.
23:37:36 T:3584 M:1124831232 DEBUG: Thread 3584 terminating
23:37:36 T:6076 M:1124851712 DEBUG: FileCurl::Close(034BFCF8) http://216.235.94.14/play?s=psychopathrecords&d=live365
23:37:36 T:6076 M:1124888576 ERROR: MP3Codec: Error reading file
23:37:36 T:6076 M:1124888576 ERROR: MP3Codec: Unable to determine file format of http://216.235.94.14/play?s=psychopathrecords&d=live365 (corrupt start of mp3?)
23:37:36 T:2872 M:1124888576 DEBUG: Thread 2872 terminating
23:37:36 T:6076 M:1124917248 DEBUG: FileCurl::Close(034BF8F0) http://216.235.94.14/play?s=psychopathrecords&d=live365
23:37:36 T:6076 M:1124937728 ERROR: CAudioDecoder: Unable to Init Codec while loading file http://216.235.94.14/play?s=psychopathrecords&d=live365
23:37:36 T:6076 M:1124941824 DEBUG: CAnnouncementManager - Announcement: PlaybackStopped from xbmc
23:37:36 T:6076 M:1124941824 ERROR: Playlist Player: skipping unplayable item: 0, path [http://216.235.94.14/play?s=psychopathre...d=live365]
23:37:36 T:6076 M:1124941824 DEBUG: Playlist Player: one or more items failed to play... aborting playback
we both have a revo 3610 with win7 x64
im running 10.0 r35647 (dec 17 build)
and if it matters im using transparency
3.11.1
im not sure what version of 10 he is running.
any help would be cool. thanks in advance.
I get the same error. Presumably Dharma doesn't like something in the stream, though I note that the stream does work with mplayer. It might be worth posting a bug report on trac.xbmc.org.
JR
To me worked well but with an issues that not all channels work. Reverting to 9.1 release all channels in the strm file works!
Have been unable to locate the fault since.
I had a thread with the issue but none was able or couldn't be arsed to look into.
As for today this is still an issue but i don't bother much since the channels that do not work (but does on VLC) aren't that good.
If only the devs would fix mpeg2 deinterlacing in DXVA...
