2011-01-14, 21:21
I'd like to set up a centralized database for my XBMC clients. I've reviewed the thread here: http://forum.xbmc.org/showthread.php?tid=85654 but I've hit a catch-22 problem.
I have a server I run 24*7. It is a ESXi v4.1 box on which I set up servers as needed. I've set one up (Win7 x64 pro) as my HT server to provide services as needed. IE - Until XBMC has a built in PVR I'm using SageTV which is set up there. The HT server has no AV, the firewall is disabled, and UAC is off.
I started the centralized database install process and it went fine until I realized I need to have XBMC installed. So I installed it (v10.0) but I get the error when I try to run it:
CApplication::Create() failed - check log file and that it is writable.
The log file shows FATAL: CApplication::Create: Unable to init rendering system which as best I can tell from my research indicates the virtual video card isn't compatible with XBMC.
The central database requires a local XBMC to set up sources; but I cannot run XBMC to do so. Am I stuck with no solution?
Log:
09:26:26 T:1968 M:2352463872 NOTICE: -----------------------------------------------------------------------
09:26:26 T:1968 M:2352455680 NOTICE: Starting XBMC, Platform: Windows 7, 64-bit (WoW) build 7600. Built on Dec 17 2010 (SVN:35647, compiler 1500)
09:26:26 T:1968 M:2352455680 NOTICE: Intel® Xeon® CPU L3110 @ 3.00GHz
09:26:26 T:1968 M:2352451584 NOTICE: Desktop Resolution: 1280x1024 16Bit at 60Hz
09:26:26 T:1968 M:2352451584 NOTICE: Running with administrator rights
09:26:26 T:1968 M:2352451584 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
09:26:26 T:1968 M:2352451584 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
09:26:26 T:1968 M:2352451584 NOTICE: special://masterprofile/ is mapped to: C:\Program Files (x86)\XBMC\portable_data\userdata
09:26:26 T:1968 M:2352451584 NOTICE: special://home/ is mapped to: C:\Program Files (x86)\XBMC\portable_data
09:26:26 T:1968 M:2352451584 NOTICE: special://temp/ is mapped to: C:\Program Files (x86)\XBMC\portable_data\temp
09:26:26 T:1968 M:2352451584 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
09:26:26 T:1968 M:2352451584 NOTICE: Log File is located: C:\Program Files (x86)\XBMC\xbmc.log
09:26:26 T:1968 M:2352451584 NOTICE: -----------------------------------------------------------------------
09:26:26 T:1968 M:2352435200 NOTICE: Setup SDL
09:26:26 T:1968 M:2352185344 NOTICE: Found screen: Dummy Monitor on RDPDD Chained DD, adapter 0.
09:26:26 T:1968 M:2352177152 NOTICE: Primary mode: 1280x1024 @ 60.00 - Full Screen
09:26:26 T:1968 M:2351984640 NOTICE: load settings...
09:26:26 T:1968 M:2351755264 NOTICE: special://profile/ is mapped to: special://masterprofile/
09:26:26 T:1968 M:2351751168 NOTICE: loading special://masterprofile/guisettings.xml
09:26:26 T:1968 M:2351738880 ERROR: special://masterprofile/guisettings.xml, Line 0
Failed to open file
09:26:26 T:1968 M:2351734784 ERROR: Unable to load special://masterprofile/guisettings.xml, creating new special://masterprofile/guisettings.xml with default values
09:26:26 T:1968 M:2351435776 NOTICE: Getting hardware information now...
09:26:26 T:1968 M:2351435776 NOTICE: Checking resolution 12
09:26:26 T:1968 M:2351431680 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
09:26:26 T:1968 M:2351423488 NOTICE: Loaded playercorefactory configuration
09:26:26 T:1968 M:2351423488 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
09:26:26 T:1968 M:2351423488 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
09:26:26 T:1968 M:2351419392 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
09:26:26 T:1968 M:2351419392 NOTICE: Default DVD Player: dvdplayer
09:26:26 T:1968 M:2351419392 NOTICE: Default Video Player: dvdplayer
09:26:26 T:1968 M:2351419392 NOTICE: Default Audio Player: paplayer
09:26:26 T:1968 M:2351423488 NOTICE: Loading media sources from special://masterprofile/sources.xml
09:26:27 T:1968 M:2346999808 FATAL: CApplication::Create: Unable to init rendering system
Log:
Failed to open file
