2011-01-15, 04:49
PREVIOUS STABLE PPA
https://launchpad.net/~team-xbmc/+archiv...ous-stable
It is asking for me to sign up with sourceforge.
I upgraded to 10.0 but I am having problems with audio.
I lost sound using firefox on my htpc. If I run the cmd string
aplay -Dplughw:0,3 /usr/share/sounds/alsa/Front_Center.wav as xbmc is loading I get sound accross the hdmi (If I wait until xbmc is loaded than I get resource busy). Once sound is working (Aplay string) if I go to the internet through launcher Hulu, Fancast and all work fine including sound over hdmi. If I use xbmc apps (Music or video) I have sound also, but I can not go back out to the internet or I will have no sound. I have to re-load xbmc (and while it is loading run cmd string above, that is key) and then go directly to the internet, everything is fine.
When I run the above cmd string after leaving the internet, sound still works. But if I play music for a few seconds or watch a video and run the aplay string, it tells me that the sound device resources are busy. I did not have this problem before so I was going to try and go back a release or two without doing a build.
