2011-01-15, 09:25
2011-01-15, 09:25
2011-01-15, 19:47
Opinions? Yeah, nice remote
But seriously, I have a the same problem with another remote - but as yet Im yet to find a solution due to the large amount of long/complex/conflicting/vague posts.
Doesnt help I know, just thought I would let you know I share your pain
http://forum.xbmc.org/showthread.php?tid=90049
2011-01-15, 19:54
irw log?
xbmc debug log?
xbmc debug log?
2011-01-16, 02:46
deleted.
2011-01-16, 06:47
trying to do "sudo dpkg-reconfigure lirc"
returning command
/usr/sbin/dpkg-reconfigure: lirc is broke or not fully installed
returning command
2011-01-16, 20:05
any help?
2011-01-16, 20:48
ok removed the /etc/lirc directory and then reinstalled lirc again.
sudo apt-get install lirc
during reconfigure I picked Windows Media Center remotes /all
and for transceiver I selected none.
2011-01-16, 20:49
after reboot tried the "irw" command still not showing any outputs when I press the remotes buttons.
2011-01-16, 20:55
hardware.conf
lircd.conf
REMOTE="Windows Media Center Transceivers/Remotes (all)"
REMOTE_MODULES="lirc_dev lirc_mceusb"
REMOTE_DRIVER=""
REMOTE_DEVICE="/dev/lirc0"
REMOTE_SOCKET=""
REMOTE_LIRCD_CONF="mceusb/lircd.conf.mceusb"
REMOTE_LIRCD_ARGS=""
TRANSMITTER="None"
TRANSMITTER_MODULES=""
TRANSMITTER_DRIVER=""
TRANSMITTER_DEVICE=""
TRANSMITTER_SOCKET=""
TRANSMITTER_LIRCD_CONF=""
TRANSMITTER_LIRCD_ARGS=""
START_LIRCD="true"
START_LIRCMD=""
LOAD_MODULES=""
LIRCMD_CONF=""
FORCE_NONINTERACTIVE_RECONFIGURATION="false"
lircd.conf
#This configuration has been automatically generated via
#the Ubuntu LIRC package maintainer scripts.
#It includes the default configuration for the remote and/or
#transmitter that you have selected during package installation.
#Feel free to add any custom remotes to the configuration
#via additional include directives or below the existing
#Ubuntu include directives from your selected remote and/or
#transmitter.
#Configuration for the Windows Media Center Transceivers/Remotes (all) remote:
include "/usr/share/lirc/remotes/mceusb/lircd.conf.mceusb"
2011-01-17, 20:33
bueller?
2011-01-18, 23:40
anybody want to help me out. i've exhausted myself.
2011-01-19, 01:45
invoke-rc.d lirc stop
lircd -n -d /dev/lirc0 /usr/share/lirc/remotes/mceusb/lircd.conf.mceusb
In another window
irw.
What does it do?
In another window
irw.
What does it do?
2011-01-19, 01:59
Try:
This should list up all connected usb peripheral that is connected and
detected. Does it list your HP IR reciever ?
I have a xbox usb dongle and i have from lsusb:
So this should be the first thing you should verify.
Doing
Should give you output in terminal window when you press keys on your remote. If not then something is wrong with your setup, either distro,kernel or lirc.
whats your output on these:
lsusb
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 045e:0284 Microsoft Corp. Xbox DVD Playback Kit
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Doing
irw
cat /etc/issue
uname -r
2011-01-19, 07:09
I'd like to add my frustration in adding a Rosewill RRC-126 to my new HTPC running XBMC Live 10.0. I've succeeded in messing things up so badly I had to reinstall, so I'd like to avoid doing that again if at all possible.
Here's what I can tell you so far:
lsusb does detect my device as a Formosa Industries Corporation device, but that device is not listed in the lirc configuration file under devices (the vendor is, however, and there are a couple of older(?) devices listed). I tried to add my device and reinstall the lirc package, but that generated errors on the build related to a missing kernel source that I was unable to resolve, and trying to reinstall a new kernel caused even more issues. I feel that this problem would be solved if I had been able to rebuild my lirc and install it, but the kernel issue is new to me, and I haven't had any success finding anyone with a similar problem. I've tried every solution I can find for the kernel problem, but all attempts result in errors (sudo make oldconfig, etc.).
I hope someone can help me add my device and reinstall lirc, because once I get past that, I think I'll be in business!
Thanks in advance,
-z
PS: If this counts as hijacking the thread, I apologize in advance and will repost to a new topic, just let me know!
Thanks in advance,
-z
2011-01-19, 21:54
its cool. I'm leaning towards a fresh install of Dharma just because who knows what i've changed and what I've messed up.
then once I'm fresh I can follow some correct steps and not just poke about hoping for some result.
