2011-01-17, 03:53
2011-01-17, 06:35
This is great Sinvida. The green font looks great, and thanks for putting statistics back in. One question though, why did you remove the aeon like recently added? I liked the look of that, any way to make it optional? Also it would be great it you could implement the imdb rating option like Cirrus-Extended. Thanks
2011-01-17, 09:31
B-fire, great work! If you send me the XML files I will update the skin again.
@smush420: yeah I took it out because somehow i couldn't manage Yet to get the statistics in. I will look at it again.
2011-01-17, 21:34
Yay, I think I fixed the next aired refresh problem. Seems to work now! Updated the download file.
2011-01-18, 02:37
Sinvida Wrote:Yay, I think I fixed the next aired refresh problem. Seems to work now! Updated the download file.
This is truly fantastic. I will upload the files now. Not sure why I didn't before, sorry about that.
edit: Here they are: http://www.mediafire.com/?sduv3lh0o8chhc3
2011-01-18, 09:20
Great job on that skin !!! It's my new one on my Revo. Thanks !!!
Anyway, i've got some problems. Artist Fanart don't work when i hit the TAB button. I have the CDArt and the covers but just a black screen as a Fanart.
In the same way, i don't have a Now Playing on the home like other skins.
Any help will be appreciated.
2011-01-18, 11:22
Mickamac Wrote:Great job on that skin !!! It's my new one on my Revo. Thanks !!!
I Will check tonight if it's à cirrus related problem or à bug in THE mod. I'll get back on this. <- Solved. Download Sinus 1.1 please.
@b-fire: Will look at THE files tonight. Cheers mate!
2011-01-18, 22:37
Uploaded a new version: Sinus1.1 (thanks to B-Fir3).
Could use some help on the recently added coding. Somehow I can't get the tv show folder to appear when scrolling through recently added.
Download here! (This version does have a little bug with recently added. Versions 1.0 in topicstart doesn't have the bug but misses some features)
Home Screen
- Moved time to the left in case of negative temperatures
TV - Show level
*Rightlist View
- Adjusted labels to maintain a unified look
- Added landscape.jpg support
*Bannerwall View
*Fanart View
- Adjusted focus position to center thumb
*Wall View
- Added tv show plot
NextAired
- Added <width> value 450 to prevent long episode names from colliding with network flags
Recently Added
- Aeon meets cirrus: if you scroll through recently added, you can read the plot. See screenshot.
Music visualisation
- Added fanart in the background (requested by Mickamac)
Home Screen
TV - Show level
*Rightlist View
*Bannerwall View
*Fanart View
*Wall View
NextAired
Recently Added
Music visualisation
2011-01-18, 23:12
the recently added rocks,cool idea.
2011-01-19, 00:23
Love the recently added, my favourite feature from aeon. Have you thought about changing the back ground to the fanart of the selected item?
2011-01-19, 09:16
Sinvida Wrote:Uploaded a new version: Sinus1.1 (thanks to B-Fir3).
Home Screen
TV - Show level
*Rightlist View
*Bannerwall View
*Fanart View
*Wall View
NextAired
Recently Added
Music visualisation
Perfect Job on that skin, thanks a lot !!!
2011-01-19, 21:01
Just installed your newest version and I am impressed. Thanks for the hard work.
I am having issues getting bannerwallview to work. The info on the bottom populates correctly with logo and description but the banners don't show up. Just place holders where they should be. I am I missing something?
Thanks in advance,
Thanks in advance,
2011-01-19, 21:19
Yeah you need à landscape.jpg in THE folder of THE tv show. Unfortunately you need to download them manually. You can get them from xbmcstuff.com.
2011-01-19, 23:03
Sinvida Wrote:Yeah you need à landscape.jpg in THE folder of THE tv show. Unfortunately you need to download them manually. You can get them from xbmcstuff.com.
Thanks . It was the banners that weren't showing but putting it in the folder like you said and naming it banner.jpg solved it.
2011-01-20, 03:45
dascmo Wrote:Thanks . It was the banners that weren't showing but putting it in the folder like you said and naming it banner.jpg solved it.
Exactly it! I love this skin.
