I'll try to explain my problem here, as i really don't what's causing following bug:
Skins:
cirrus extended v2 SVN
Rapier SVN
Fusion Migma
If i start ptv from the addon section everything's ok, but when i start the script by favourites, exiting ptv let loose focus on home menu and can't navigate anymore. Have to close xbmc (ctrl alt delete)
I've tried the same with following skins and everything's working as excepted:
Aeon Nox SVN
reFocus
Simplicity SVN
Running latest nightly on win 7.
Anyone an idea what could be the problem?
Thanx in advance.
I don't think the new versions work with SMB shares. Whenever I try to run the stable pre I get the "Unable to populate channels" message. Version 1.2.1 works fine though.)
In the log I see this:
19:03:23 T:2995731312 M:3233906688 DEBUG: GetSetsNav query: SELECT sets.idSet,sets.strSet,COUNT(1) AS c,count(files.playCount) FROM sets JOIN setlinkmovie ON sets.idSet=setlinkmovie.idSet JOIN movie ON setlinkmovie.idMovie=movie.idMovie JOIN files ON files.idFile=movie.idFile where movie.idMovie in (select movieview.idMovie from movieview WHERE (idMovie in (select idMovie from genrelinkmovie join genre on genre.idGenre=genrelinkmovie.idGenre where genre.strGenre LIKE '%Standup%'))) GROUP BY sets.idSet HAVING c>1
19:03:23 T:2995731312 M:3233906688 DEBUG: GetMoviesByWhere query: select * from movieview WHERE (idMovie in (select idMovie from genrelinkmovie join genre on genre.idGenre=genrelinkmovie.idGenre where genre.strGenre LIKE '%Standup%')) and movieview.idMovie NOT in (select idMovie from setlinkmovie) ORDER BY RANDOM()
19:03:23 T:2995731312 M:3233906688 DEBUG: Time for actual SQL query = 31
19:03:23 T:2926570352 M:3233906688 DEBUG: Compress - using DXT1 (min error is: 17.12:0.00)
19:03:23 T:2995731312 M:3235176448 DEBUG: Time to retrieve movies from dataset = 194
19:03:23 T:2906418032 M:3235483648 DEBUG: script.pseudotv-ChannelList: runActions 2 on channel 1
19:03:23 T:2906418032 M:3235483648 DEBUG: script.pseudotv-VideoParser: getVideoLength smb://192.168.1.103/Levithan/Stand Up Comedy/Russell Peters - Red White and Brown (2008)/Russell Peters - Red White and Brown (2008).avi
19:03:23 T:2906418032 M:3235483648 DEBUG: script.pseudotv-VideoParser: Unable to find the file
This file does exist/is scanned into the library/and xbmc can play it just fine. Running that path from my ubuntu box works fine as well.
Here's the complete debug log:
http://pastebin.com/bL7KWhUV
Jason102 Wrote:RockDawg: you have the weirdest problems. I...don't know. Know that if you skip around in a channel (going forward or back, pause, ff, rw) then those shifts are ignored when resuming.
Good to know, but I'm not doing any of that. What strikes me about these problems is that they're consistently reproducible on all of my machines across multiple OS's and even different versions of XBMC. I don't know what would be so unique about my systems that would give me these bugs and nobody else. Especially when my systems differ from each other. The only other thing I can think of is that I'm using a mysql central db and not the default sqlite. Anyone else using PTV with mysql?
Edit: posted in wrong thread
butchabay: You're seeing some odd skin issue...I can't fix this in PTV. You might want to ask this same question in one of the threads specific to one of those skins.
mcorcoran: You say that 1.2.1 works fine...did you also use 1.2.1 in Eden? I fully expect that SMB shares won't work in Eden in anything except Windows. This was a change in Eden that I'm not a big fan of, but one I also haven't figured out a way around.
RockDawg: I'm using a central MySQL server, so that's not the problem. Are you doing any channel sharing by chance? If you are, try a single machine without it to see if you still have the problem.
No, I'm not doing any channel sharing. I disabled that since you said it wouldn't work in Linux due to the Samba issues.
Jason102
I think i've found the problem, it's ofcourse skin related, i'll test and report back. Thanx anyway.
I've tried out the IceLibrary thing, and it appears that some code that I put in to check for errors is the thing causing problems. I don't want to get rid of the code, so I need some way to turn it off when trying to play a stream. Anyway, I'll figure that out.
Can someone else test this to make sure they are seeing IceLibrary work properly? Just edit resources/lib/Overlay.py. Look for:
if self.notPlayingCount == 3:
self.end()
return
Put the pound sign (#) in front of each line:
# if self.notPlayingCount == 3:
# self.end()
# return
If that fixes the issue, I can look into make some sort of permanent solution.
Jason102 Wrote:I've tried out the IceLibrary thing, and it appears that some code that I put in to check for errors is the thing causing problems. I don't want to get rid of the code, so I need some way to turn it off when trying to play a stream. Anyway, I'll figure that out.
self.end()
return
# self.end()
# return
thanks heaps for looking into this, if i wasn't late for work i would check this..
hopefully someone can look into this and we can get it working??
self.end()
return
# self.end()
# return
Hi, I gave that a try but unfortunately it didn't work for me, PsuedoTV still stops when I try to change channel. I am using Transparency SVP, a recent nightly build and Icelibrary with a premium Megaupload account.
Hope you can fix this problem, having Icelibrary and PTV working together would truly make an unbeatable TV experience!
Anyone have any ideas on how to make a channel from a static playlist? I'm trying to make some Christmas channels; I've tried a few different techniques (directory, smart playlist searching for the word "Christmas"), but I'm not happy with the results. Seems like XBMC doesn't take kindly to the lowly static playlist, and I can't figure out a way to make a PTV channel from one. Any thoughts out there?
badwornthing Wrote:Hi, I gave that a try but unfortunately it didn't work for me, PsuedoTV still stops when I try to change channel. I am using Transparency SVP, a recent nightly build and Icelibrary with a premium Megaupload account.
i also tried and could not get to work
aeon nox skin ,nightly build with premium mega account
any other ideas??
This is awesome - without a word of a lie what I have been waiting for...I have no idea where else to simply shout THANK YOU!
Damn, I was hoping that it would work. Only a problem when changing channels, eh? I'll keep looking...I don't have a premium account so it takes a bit longer to test.
TheOddLinguist: I don't necessarily have a good solution for you. What I did was to add all of my Christmas movies to the Holiday genre, and then just create a genre channel.
Looking forward to full IceLibrary support! Come on jason, we believe in you
