steppedup Wrote:Jason - love this script!!! Very nice work!
I think I found an easy way to establish duration for everything for those of us who have terabytes of shows stored up.
I have 5 or 6 huge usb drives ...with TV Series folders on each. (one folder each).
They are my sources for TV shows.
I created one playlist for each:
Playlist type: episodes
(Path) Starts With F:\TV_Shows
with no limit.
Open up the playlist and just watch the duration grow and grow and grow....
A little bit easier than going folder to folder.
[edit] I found that I had to scroll down to the very bottom of the Playlists in order to get them to start updating duration.
To create an "all episodes" playlist, I selected (Year) (Greater Than) 1900. That pulled in all episodes in my library into a single playlist. All 6820 items. It's still calculating the total duration.
I'm still working out a playlist structure and nomenclature that will do what I want and help me organize the numerous playlists that I will be creating.
episodes - (tvshow - limit - order)
episodes - (category)
movies - (category)
channel - (description)
So my playlist directory would look like:
channel - trekkie tv - limit to 25 - random
channel - 80s - limit to 25 - random
channel - current - limit to 25 - random
episodes - 24 - all - first aired
episodes - action and adventure - limit to 25 - random
episodes - last 2 weeks - all - first aired
episodes - star trek - all - first aired
episodes - star trek - limit to 25 - random
episodes - star trek the next generation - limit to 25 - random
episodes - the x-files - all - first aired
episodes - the x-files - limit to 50 - random
movies - 2010 and newer - all - random
movies - 80s - limit to 25 - random
movies - action - limit to 25 - random
I would use my (all - first aired) whenever I wanted to watch a series in order and use the (limit - random) whenever I wanted to have a broadcast type channel.
Then once I have my channel playlist set the way I want, I copy it to Channel_X filenames based on the channel lineup I want.
I am still working out the randomness of the shows within a channel to find which way works best. I am going to try adding the following two playlists to a channel which limit to 24 and see how many of each show I get in my playlist.
It's kind of a trial and error approach at this point. It will be a lot of work to setup but hopefully once setup not too bad to maintain.
