2011-12-06, 08:48
RockDawg Wrote:No problem. Again, I'm not real knowledgeable about skinning. I just figured some stuff out while trying to mod skins to my liking. butchabay showed me the fix as it pertaims to Cirrus Extended, and I was able to figure out how that applied to MQ3.
Basically, that is setting the default control whenever the home page appears. In other words it's setting what on the home page should have focus. 4056 is the Startup Assistant in MQ3. I'm not totally sure, and I could certainly be wrong, but I think it is the wizard-like tool that helps you setup MQ3 the first time you run it. I'm not sure how that comes into to play later though. 300 is the id for the horizontal main menu. Obviously, that is what we are wanting to have the focus.
So by changing it, we are saying whenever the home page is loaded, give the focus to the main menu instead of the "Startup Assistant". Like I said though, without me fully understanding what that is, what it's supposed to do or when it's supposed to have focus, it's likely my change broke something. With any luck it's something you'll never use or miss, but you might be missing out on a cool feature of MQ3. I just don't know. I suppose that setting could be a bug that should be permanently changed, but I would trust that the creator(s) of MQ3 know far more about what they are doing than I do.
That's indeed the best method, the creator should see and fix it, i needed to change some more things than that. As the ID will return to show recently added or random items on home. So if you just change the Window ID you'll break other stuff.
