Answering oldest to newest:
ComputerCarl Wrote:If I have a playlist that contains ISOs with menus, they play fine...is there any way to navigate these from inside PTV?
I'm amazed you got ISOs to play inside of PTV. Generally they don't have a duration associated with them (because of said menus) so I just reject them. I haven't made any way to actually use menus because of this.
mmartell Wrote:are we still in Feature Request mode
Requests are always welcome, but I'm not sure we're in Feature Development mode right now. At least nothing big at the moment...
mmartell Wrote:ability to go forward AND backward in time. I suggest restricting the user to current/future events.
I've heard this request before, and someone else even mentioned in recently. I won't do this. I know you'd like it, and if someone else coded an option and put it in I may put it in the release. The problem is that this is an added restriction for the sake of making this more "TV-like". While the plugin certainly tries to act like a TV, I'm not going to impose restrictions just because they exist there.
mmartell Wrote:three number click wheel allowing for direct channel input.
I do want a way for users to skip around channels in the EPG. This has been on my list for a while, I just haven't gotten around to it.
mmartell Wrote:references to Livestreams...couldn't the guide for that channel be built as one un-ending block
It could, but I just really hate that solution. It really kind of breaks the EPG, you only ever know what's currently on. This is very TV-like, but I hate the restriction. That being said, I can't say that streaming channels won't come in the future, in which case this sort of thing may be the only way to do it.
dsync89 Wrote:audio problem is still not fixed for Mac OS
I don't know why this happens, it's certainly nothing in my code. Given that, I may be able to "fix" it by muting before the channel change and unmuting right after. I'll look and see how easy this is to do through XBMC APIs.
djtoll Wrote:[Release] PseudoTV Skin for the xbmc Joggler Skin
Thank you! New skins are always appreciated. It will be in the next release.
dsync89 Wrote:Why is the info box doesn't show my TV info when I use my custom smart playlist?
Are you sure it's a smart playlist channel? Only filenames will show up on directory channels, just by the nature of it...
dsync89 Wrote:One feature that would be nice is the ability to swap the existing channels.
Agreed. One of the many things on the to-do list.
jmj52 Wrote:they never appear in the guide
You're going to need to get a debug log for me to help. Remember that if background updating is on then all channels won't necessarily appear right away, wait for a few minutes and see if notifications tell you that they're available.
CameronC Wrote:anyone know a fix for a Script Failed: Config.py error box
Please get a debug log.
