How can I set the default language to english for Psuedo TV. Some of my rips I didn't know what I was doing and ripped Russian as the main track and english as the secondary. ;( Any help on this would be great.
@ tdhz77
IF You use frodo
you can go to appearance setting >> international
(2013-02-18, 12:27)tdhz77 Wrote: [ -> ]How can I set the default language to english for Psuedo TV. Some of my rips I didn't know what I was doing and ripped Russian as the main track and english as the secondary. ;( Any help on this would be great.
THIS post I made earlier in the thread.
(2013-02-15, 03:25)thepineapple Wrote: [ -> ]Q: How can I force PseudoTV to play 240p videos? It refuses. (videos which play fine in the XBMC library)
They should play in PTV..I have tons of stuff I captured to Divx from VHS back in the day and many of those are 240p. (320 x 240)
Make sure the index on them isn't broken. It could be the file-type. Stuff like 3GP and WEBM files don't function properly for me in PTV.
on Frodo
Having an issue with loading a channel
channel 200 never loads
and it has 3 of those generated playlists inside it.
Why can't it parse it?
02:18:14 T:1444 ERROR: CWINFileSMB: Unable to open file \\192.168.1.60\d\xbmc\userdata\addon_data\service.skin.widgets\settings.xml Error: 2
02:18:14 T:3640 NOTICE: StorageServer Module loaded RUN
02:18:14 T:3640 NOTICE: StorageClient-2.5.0 Starting server
02:18:14 T:3640 NOTICE: StorageServer-2.5.0 Storage Server starting C:\Users\Danny\AppData\Roaming\XBMC\userdata\addon_data\script.common.plugin.cache\commoncache.db
02:18:14 T:3640 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.NameError'>
Error Contents: global name 'sqlite' is not defined
File "C:\Users\Danny\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py", line 40, in <module>
run()
File "C:\Users\Danny\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py", line 35, in run
s.run()
File "C:\Users\Danny\AppData\Roaming\XBMC\addons\script.common.plugin.cache/lib\StorageServer.py", line 189, in run
if not self._startDB():
File "C:\Users\Danny\AppData\Roaming\XBMC\addons\script.common.plugin.cache/lib\StorageServer.py", line 116, in _startDB
except sqlite.Error, e:
NameError: global name 'sqlite' is not defined
02:18:14 T:2560 NOTICE: Thread CRssReader start, auto delete: false
02:18:14 T:2976 ERROR: Control 400 in window 10107 has been asked to focus, but it can't
02:18:21 T:4432 NOTICE: Thread Background Loader start, auto delete: false
02:18:31 T:4028 NOTICE: Previous line repeats 3 times.
02:18:31 T:4028 NOTICE: Service: 21264 actors took 21.79200005531311
02:18:34 T:344 NOTICE: Thread Background Loader start, auto delete: false
02:19:00 T:2200 NOTICE: Previous line repeats 1 times.
02:19:00 T:2200 NOTICE: Thread XBPyThread start, auto delete: false
02:19:00 T:2200 NOTICE: -->Python Interpreter Initialized<--
02:19:00 T:2916 NOTICE: Thread XBPyThread start, auto delete: false
02:19:00 T:2916 NOTICE: -->Python Interpreter Initialized<--
02:19:00 T:2916 ERROR: C:\Users\Danny\AppData\Roaming\XBMC\addons\Jasonra-XBMC-PseudoTV-dc925d3\resources\lib\Overlay.py:70: DeprecationWarning: object.__init__() takes no parameters
xbmcgui.WindowXMLDialog.__init__(self, *args, **kwargs)
02:19:00 T:2916 ERROR: C:\Users\Danny\AppData\Roaming\XBMC\addons\Jasonra-XBMC-PseudoTV-dc925d3\resources\lib\Overlay.py:41: DeprecationWarning: object.__init__() takes no parameters
xbmc.Player.__init__(self, xbmc.PLAYER_CORE_AUTO)
02:19:16 T:2916 ERROR: script.pseudotv-ChannelList: makeChannelList Problem parsing playlist C:\Users\Danny\AppData\Roaming\XBMC\userdata\addon_data\script.pseudotv\cache\generated\Show_Workaholics_random.xsp
02:19:16 T:2916 ERROR: script.pseudotv-ChannelList: makeChannelList Problem parsing playlist C:\Users\Danny\AppData\Roaming\XBMC\userdata\addon_data\script.pseudotv\cache\generated\Show_New Girl_random.xsp
02:19:16 T:2916 ERROR: script.pseudotv-ChannelList: makeChannelList Problem parsing playlist C:\Users\Danny\AppData\Roaming\XBMC\userdata\addon_data\script.pseudotv\cache\generated\Network_HBO.xsp
02:19:16 T:2916 ERROR: script.pseudotv-ChannelList: makeChannelList Problem parsing playlist C:\Users\Danny\AppData\Roaming\XBMC\userdata\addon_data\script.pseudotv\cache\generated\Show_Family Guy_random.xsp
I am having a problem in which Psuedotv gets stuck at 12% when first running. Runing the newest pre-build (2.1.0) on frodo. Any workaround?
Looking around, it looks like it may be bcause I have some m2ts files. Any way to stop PTV from adding those?
(2013-02-20, 03:12)asr10 user Wrote: [ -> ]I am having a problem in which Psuedotv gets stuck at 12% when first running. Runing the newest pre-build (2.1.0) on frodo. Any workaround?
Smart playlist rule
File - Does Not Contain - M2TS
I've been trying to post this in the PseudoTV section of the forum but it will NOT (for some strange reason) allow me to post it there. It keeps saying I'm over the 85 character limit. ANY help would be MOST appreciated as I think this addon is brilliant.
(MOD Edit: Merged into main PseudoTV thread here. Also shortened thread title to avoid error message)
09:52:43 T:11156 NOTICE: -->Python Interpreter Initialized<--
09:52:43 T:11156 ERROR: EXCEPTION: Unimplemented method: executehttpapi::XBMCAddon::xbmc::executehttpapi(...)
09:52:43 T:11156 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.RuntimeError'>
Error Contents: Unimplemented method: executehttpapi::XBMCAddon::xbmc::executehttpapi(...)
File "C:\Users\Darrin\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-master\default.py", line 37, in <module>
if xbmc.executehttpapi("GetGuiSetting(1, services.webserver)")[4:] == "False":
RuntimeError: Unimplemented method: executehttpapi::XBMCAddon::xbmc::executehttpapi(...)
(2013-02-20, 09:57)Doctor3D Wrote: [ -> ] (2013-02-20, 03:12)asr10 user Wrote: [ -> ]I am having a problem in which Psuedotv gets stuck at 12% when first running. Runing the newest pre-build (2.1.0) on frodo. Any workaround?
Smart playlist rule
But isnt that for a single channel? Or can I somehow have that apply to my entire library before PTV loads and creates the channels?
(2013-02-21, 03:47)asr10 user Wrote: [ -> ] (2013-02-20, 09:57)Doctor3D Wrote: [ -> ] (2013-02-20, 03:12)asr10 user Wrote: [ -> ]I am having a problem in which Psuedotv gets stuck at 12% when first running. Runing the newest pre-build (2.1.0) on frodo. Any workaround?
Smart playlist rule
Yeah it's per playlist\channel -- but, i've found that's really the only way to make a 'good' channel with PTV.
You'll find many other reasons, besides this situation, where a playlist is necessary. -Making a studio channel -for example- and getting 12 animation movies in a roll -or- making a "Family" channel for kids and having half of the decent PG or soft PG-13 missing.
In my opinion and experience (with my content quantity), PTV isn't being used to its full potential without complex and well-designed playlists.
My Quantity for reference:
~2,500 Movies
~1,000 TV Shows
People that have a lot more than this probably wouldn't notice the problems with generic playlists as much.
There's an issue with adding specific shows to a channel when you have a large library (i think)
The issue is when you navigate through your list of shows mine only shows A-L on shows starting from the begginning and pressing forward through the list.
Then I start at Z and go backwards I can go Z-P
this leaves showing starting with M-O that can't be added via the in XBMC GUI. Using a 3rd party channel creator I was able to add the shows I wanted.
This makes me believe that over a certain amount of show titles, it will simply not show them all.
Since this has disappeared...quickly, is it possible for a mod to move it to the right section? And no, I STILL can't post it there myself.
(MOD Edit: Merged into main PseudoTV thread here)
Are you trying to use it with XBMC Frodo 12 or Eden 11? Since there's no httpapi in Frodo you get:
"Unimplemented method: executehttpapi::XBMCAddon::xbmc::executehttpapi"
(2013-02-21, 16:27)live4ever Wrote: [ -> ]Are you trying to use it with XBMC Frodo 12 or Eden 11? Since there's no httpapi in Frodo you get:
I'm trying to use it with Frodo, sorry I didn't specify that, thanks.
Hi, hopefully somebody could help me out. I am having trouble getting Hulu streams to work in PTV. I have the streams exported into the library and they work fine but PTV never picks them up. I can get Amazon streams to be picked up fine and put on the proper stations but never the Hulu streams. I can watch them from the library but never PTV. Any help would be great. Thanks!
