I'm running the pre-stable version located on page 1. Running Frodo, both 12.0 and 12.1. Channels defined of type "TV Networks" are not showing up in the EPG.
I uncommented the debug log to show the JSON results, here is the beginning of it:
Logs pertaining to a channel rebuild.
12:05:23 T:12056 DEBUG: CApplication::ExecuteXBMCAction : To RunAddon(script.pseudotv)
12:05:23 T:12056 INFO: initializing python engine.
12:05:23 T:12056 DEBUG: new python thread created. id=11
12:05:23 T:12224 NOTICE: Thread XBPyThread start, auto delete: false
12:05:23 T:12224 DEBUG: Python thread: start processing
12:05:23 T:12224 NOTICE: -->Python Interpreter Initialized<--
12:05:23 T:12224 DEBUG: XBPyThread::Process - The source file to load is C:\Users\Boots\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-stable-pre\default.py
12:05:23 T:12224 DEBUG: XBPyThread::Process - Setting the Python path to C:\Users\Boots\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-stable-pre;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.demjson\lib;C:\Program Files (x86)\XBMC\addons\weather.wunderground\resources\lib\wunderground;C:\Users\Boots\AppData\Roaming\XBMC\addons\plugin.program.sabnzbd\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.myconnpy\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.coveapi\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.free.cable.database\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.buggalo\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.amazon.database\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.mechanize\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.xbmcswift2\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.t0mm0.common\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.cryptopy\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\plugin.video.theguild\resources\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.chardet\lib;C:\Program Files (x86)\XBMC\addons\script.module.simplejson\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.urlresolver\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.elementtree\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.metahandler\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python26.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages;
12:05:23 T:12224 DEBUG: XBPyThread::Process - Entering source directory C:\Users\Boots\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-stable-pre
12:05:23 T:12224 DEBUG: Instantiating addon using automatically obtained id of "script.pseudotv" dependent on version 2.0 of the xbmc.python api
12:05:23 T:12224 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0xf21c7d8
12:05:23 T:12224 DEBUG: Previous line repeats 1 times.
12:05:23 T:12224 INFO: Scriptresult: Success
12:05:23 T:12056 DEBUG: new python thread created. id=12
12:05:23 T:12948 NOTICE: Thread XBPyThread start, auto delete: false
12:05:23 T:12948 DEBUG: Python thread: start processing
12:05:23 T:12224 INFO: Python script stopped
12:05:23 T:12224 DEBUG: Thread XBPyThread 12224 terminating
12:05:23 T:12056 DEBUG: waiting for python thread 11 (C:\Users\Boots\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-stable-pre\default.py) to stop
12:05:23 T:12056 DEBUG: python thread 11 (C:\Users\Boots\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-stable-pre\default.py) destructed
12:05:24 T:12948 NOTICE: -->Python Interpreter Initialized<--
12:05:24 T:12948 DEBUG: XBPyThread::Process - The source file to load is C:\Users\Boots\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-stable-pre/pseudotv.py
12:05:24 T:12948 DEBUG: XBPyThread::Process - Setting the Python path to C:\Users\Boots\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-stable-pre;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.demjson\lib;C:\Program Files (x86)\XBMC\addons\weather.wunderground\resources\lib\wunderground;C:\Users\Boots\AppData\Roaming\XBMC\addons\plugin.program.sabnzbd\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.myconnpy\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.coveapi\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.free.cable.database\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.buggalo\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.amazon.database\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.mechanize\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.xbmcswift2\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.t0mm0.common\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.cryptopy\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\plugin.video.theguild\resources\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.chardet\lib;C:\Program Files (x86)\XBMC\addons\script.module.simplejson\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.urlresolver\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.elementtree\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;C:\Users\Boots\AppData\Roaming\XBMC\addons\script.module.metahandler\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python26.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages;
12:05:24 T:12948 DEBUG: XBPyThread::Process - Entering source directory C:\Users\Boots\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-stable-pre
12:05:24 T:12948 DEBUG: script.pseudotv-FileLock: FileLock instance
12:05:24 T:12948 DEBUG: script.pseudotv-Globals - Eden
12:05:24 T:12948 DEBUG: script.pseudotv-Trying Frodo
12:05:24 T:12948 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0xf21c7d8
12:05:24 T:12948 DEBUG: script.pseudotv-Globals - Frodo
12:05:24 T:12948 ERROR: C:\Users\Boots\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-stable-pre\resources\lib\Overlay.py:70: DeprecationWarning: object.__init__() takes no parameters
xbmcgui.WindowXMLDialog.__init__(self, *args, **kwargs)
12:05:24 T:12948 DEBUG: script.pseudotv-TVOverlay: __init__
12:05:24 T:12948 ERROR: C:\Users\Boots\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-stable-pre\resources\lib\Overlay.py:41: DeprecationWarning: object.__init__() takes no parameters
xbmc.Player.__init__(self, xbmc.PLAYER_CORE_AUTO)
12:05:24 T:14124 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x8e5f158
12:05:24 T:12056 DEBUG: ------ Window Init (C:\Users\Boots\AppData\Roaming\XBMC\addons\skin.aeon.nox\1080i\script.pseudotv.TVOverlay.xml) ------
12:05:24 T:12056 INFO: Loading skin file: C:\Users\Boots\AppData\Roaming\XBMC\addons\skin.aeon.nox\1080i\script.pseudotv.TVOverlay.xml, load type: LOAD_ON_GUI_INIT
12:05:24 T:12056 DEBUG: LocalizeStrings: no strings.po file exist at C:\Users\Boots\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-stable-pre\resources\language\English, fallback to strings.xml
12:05:24 T:12056 DEBUG: CGUIMediaWindow::GetDirectory ()
12:05:24 T:12056 DEBUG: ParentPath = []
12:05:24 T:12948 DEBUG: script.pseudotv-TVOverlay: onInit
12:05:24 T:12948 DEBUG: DialogProgress::StartModal called
12:05:24 T:12948 DEBUG: ------ Window Init (DialogProgress.xml) ------
12:05:24 T:12948 INFO: Loading skin file: DialogProgress.xml, load type: KEEP_IN_MEMORY
12:05:24 T:12948 DEBUG: script.pseudotv-TVOverlay: backupFiles
12:05:24 T:12948 DEBUG: script.pseudotv-Settings: Loading settings from C:\Users\Boots\AppData\Roaming\XBMC\userdata\addon_data\script.pseudotv\settings2.xml
12:05:24 T:12948 DEBUG: script.pseudotv-FileAccess: trying to open C:\Users\Boots\AppData\Roaming\XBMC\userdata\addon_data\script.pseudotv\settings2.xml
12:05:24 T:12948 DEBUG: script.pseudotv-FileAccess: Opening for reading
12:05:24 T:12948 DEBUG: script.pseudotv-VFSFile: Opening C:\Users\Boots\AppData\Roaming\XBMC\userdata\addon_data\script.pseudotv\settings2.xml
12:05:24 T:12948 DEBUG: script.pseudotv-Migrate: migration
12:05:24 T:12948 DEBUG: script.pseudotv-EPGWindow: Media Path is C:\Users\Boots\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-stable-pre\resources\skins\default\media/
12:05:24 T:12948 DEBUG: script.pseudotv-TVOverlay: readConfig
12:05:24 T:12948 DEBUG: script.pseudotv-TVOverlay: Auto off is 10800
12:05:24 T:12948 DEBUG: script.pseudotv-TVOverlay: Show info label on channel change is True
12:05:24 T:12948 DEBUG: script.pseudotv-TVOverlay: Show channel bug - False
12:05:24 T:12948 DEBUG: script.pseudotv-TVOverlay: Channel reset setting - 5
12:05:24 T:12948 DEBUG: script.pseudotv-TVOverlay: Background updating - 1
12:05:24 T:12948 DEBUG: script.pseudotv-TVOverlay: Show Next Item - True
12:05:24 T:12948 DEBUG: script.pseudotv-TVOverlay: Hide Short Items - True
12:05:24 T:12948 DEBUG: script.pseudotv-TVOverlay: Short item length - 60
12:05:24 T:12948 DEBUG: script.pseudotv-TVOverlay: Channel logo folder - C:\Users\Boots\AppData\Roaming\XBMC\addons\XBMC-PseudoTV-stable-pre\resources\images/
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: Channel Reset Setting is 5
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: Force Reset is False
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: Start Mode is 1
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: IceLibrary is False
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: findMaxChannels
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: findMaxChannels return 20
12:05:24 T:12948 DEBUG: DialogProgress::StartModal called (already running)!
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: setupChannel 1
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: runActions 1 on channel 1
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: makeChannelList 1
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: fillTVInfo
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: sendJSON
12:05:24 T:12948 DEBUG: script.pseudotv-FileAccess: trying to open C:\Users\Boots\AppData\Roaming\XBMC\userdata\guisettings.xml
12:05:24 T:12948 DEBUG: script.pseudotv-VFSFile: Opening C:\Users\Boots\AppData\Roaming\XBMC\userdata\guisettings.xml
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: determineWebServer is True
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: determineWebServer port 8152
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: determineWebServer username xbmc
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: sendJSON command: {"jsonrpc": "2.0", "method": "VideoLibrary.GetTVShows", "params": {"properties":["studio", "genre"]}, "id": 1}
12:05:24 T:11972 DEBUG: webserver: request received for /jsonrpc
12:05:24 T:12948 DEBUG: JSONRPC: Incoming request: {"jsonrpc": "2.0", "method": "VideoLibrary.GetTVShows", "params": {"properties":["studio", "genre"]}, "id": 1}
12:05:24 T:12948 DEBUG: JSONRPC: Calling videolibrary.gettvshows
12:05:24 T:12948 DEBUG: CVideoDatabase::RunQuery took 48 ms for 125 items query: SELECT * FROM tvshowview
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: found shows [[u'2 Broke Girls', ''], [u'Airwolf', ''], [u"America's Next Top Model", ''], [u'American Horror Story', ''], [u'American Idol', ''], [u'Angel', ''], [u'Bates Motel', ''], [u'Battlestar Galactica (2003)', ''], [u'Beauty and the Beast (2012)', ''], [u'Behind The Music', ''], [u'Being Human (US)', ''], [u'Black Mirror', ''], [u'Blue Mountain State', ''], [u'Boardwalk Empire', ''], [u'Breaking Bad', ''], [u'Buck Rogers in the 25th Century', ''], [u'Buffy the Vampire Slayer', ''], [u'Community', ''], [u'Continuum', ''], [u'Copper', ''], [u'Cosmos', ''], [u'Cougar Town', ''], [u'Curiosity', ''], [u'Dancing With the Stars', ''], [u'Dark Matters', ''], [u'Deadliest Catch', ''], [u'Defiance', ''], [u'Desperate Housewives', ''], [u'Dexter', ''], [u'Dirty Jobs', ''], [u'Doctor Who', ''], [u'Doctor Who (2005)', ''], [u'Dollhouse', ''], [u"Don't Trust the B---- in Apartment 23", ''], [u'Downton Abbey', ''], [u'Drugs, Inc.', ''], [u'Elementary', ''], [u'Farscape', ''], [u'Fashion Police', ''], [u'Firefly', ''], [u'Formula 1', ''], [u'Fringe', ''], [u'Frontline (PBS)', ''], [u'Game of Thrones', ''], [u'Gangland', ''], [u'Girls', ''], [u'Glee', ''], [u'Go On', ''], [u"Grey's Anatomy", ''], [u'Grimm', ''], [u'Hannibal', ''], [u'Hemlock Grove', ''], [u'Homeland', ''], [u'House of Cards (US)', ''], [u'House of Lies', ''], [u'How I Met Your Mother', ''], [u"How It's Made", ''], [u'How Stuff Works', ''], [u'How The Universe Works', ''], [u'Into the Universe with Stephen Hawking', ''], [u"James May's Man Lab", ''], [u'Jem', ''], [u'King of the Nerds', ''], [u'Locked Up Abroad', ''], [u'Lost Girl', ''], [u'Mad Men', ''], [u'Maison close', ''], [u'Metal Hurlant Chronicles', ''], [u'Modern Family', ''], [u'Modern Marvels', ''], [u"MTV2's Guy Code", ''], [u'MythBusters', ''], [u'Nashville', ''], [u'New Girl', ''], [u'Nikita', ''], [u'NOVA', ''], [u'Nurse Jackie', ''], [u'Once Upon a Time (2011)', ''], [u'Orphan Black', ''], [u'Project Runway', ''], [u'Quantum Leap', ''], [u'Red Dwarf', ''], [u'Revolution', ''], [u'Sex and the City', ''], [u'Sherlock', ''], [u'Six Feet Under', ''], [u'Smash (2012)', ''], [u'Sons of Anarchy', ''], [u'South Park', ''], [u'Spartacus', ''], [u'Star Trek', ''], [u'Star Trek: Deep Space Nine', ''], [u'Star Trek: Enterprise', ''], [u'Star Trek: The Next Generation', ''], [u'Star Trek: Voyager', ''], [u'Star Wars: The Clone Wars', ''], [u'Suburgatory', ''], [u'Survivor', ''], [u'Survivorman', ''], [u'Switched at Birth', ''], [u'The Bachelor', ''], [u'The Bachelorette', ''], [u'The Bible', ''], [u'The Big Bang Theory', ''], [u'The Carrie Diaries', ''], [u'The Doctors Revisited', ''], [u'The Face', ''], [u'The Following', ''], [u'The Guild', ''], [u'The Mindy Project', ''], [u'The New Normal', ''], [u'The Newsroom (2012)', ''], [u'The Twilight Zone', ''], [u'The Universe', ''], [u"The Victoria's Secret Fashion Show", ''], [u'The Voice (US)', ''], [u'The Walking Dead', ''], [u'Top Gear', ''], [u'Torchwood', ''], [u'Tosh.0', ''], [u'True Blood', ''], [u'United States of Tara', ''], [u'Vikings', ''], [u'Warehouse 13', ''], [u'Weeds', ''], [u'2 Broke Girls', ''], [u'Airwolf', ''], [u"America's Next Top Model", ''], [u'American Horror Story', ''], [u'American Idol', ''], [u'Angel', ''], [u'Bates Motel', ''], [u'Battlestar Galactica (2003)', ''], [u'Beauty and the Beast (2012)', ''], [u'Behind The Music', ''], [u'Being Human (US)', ''], [u'Black Mirror', ''], [u'Blue Mountain State', ''], [u'Boardwalk Empire', ''], [u'Breaking Bad', ''], [u'Buck Rogers in the 25th Century', ''], [u'Buffy the Vampire Slayer', ''], [u'Community', ''], [u'Continuum', ''], [u'Copper', ''], [u'Cosmos', ''], [u'Cougar Town', ''], [u'Curiosity', ''], [u'Dancing With the Stars', ''], [u'Dark Matters', ''], [u'Deadliest Catch', ''], [u'Defiance', ''], [u'Desperate Housewives', ''], [u'Dexter', ''], [u'Dirty Jobs', ''], [u'Doctor Who', ''], [u'Doctor Who (2005)', ''], [u'Dollhouse', ''], [u"Don't Trust the B---- in Apartment 23", ''], [u'Downton Abbey', ''], [u'Drugs, Inc.', ''], [u'Elementary', ''], [u'Farscape', ''], [u'Fashion Police', ''], [u'Firefly', ''], [u'Formula 1', ''], [u'Fringe', ''], [u'Frontline (PBS)', ''], [u'Game of Thrones', ''], [u'Gangland', ''], [u'Girls', ''], [u'Glee', ''], [u'Go On', ''], [u"Grey's Anatomy", ''], [u'Grimm', ''], [u'Hannibal', ''], [u'Hemlock Grove', ''], [u'Homeland', ''], [u'House of Cards (US)', ''], [u'House of Lies', ''], [u'How I Met Your Mother', ''], [u"How It's Made", ''], [u'How Stuff Works', ''], [u'How The Universe Works', ''], [u'Into the Universe with Stephen Hawking', ''], [u"James May's Man Lab", ''], [u'Jem', ''], [u'King of the Nerds', ''], [u'Locked Up Abroad', ''], [u'Lost Girl', ''], [u'Mad Men', ''], [u'Maison close', ''], [u'Metal Hurlant Chronicles', ''], [u'Modern Family', ''], [u'Modern Marvels', ''], [u"MTV2's Guy Code", ''], [u'MythBusters', ''], [u'Nashville', ''], [u'New Girl', ''], [u'Nikita', ''], [u'NOVA', ''], [u'Nurse Jackie', ''], [u'Once Upon a Time (2011)', ''], [u'Orphan Black', ''], [u'Project Runway', ''], [u'Quantum Leap', ''], [u'Red Dwarf', ''], [u'Revolution', ''], [u'Sex and the City', ''], [u'Sherlock', ''], [u'Six Feet Under', ''], [u'Smash (2012)', ''], [u'Sons of Anarchy', ''], [u'South Park', ''], [u'Spartacus', ''], [u'Star Trek', ''], [u'Star Trek: Deep Space Nine', ''], [u'Star Trek: Enterprise', ''], [u'Star Trek: The Next Generation', ''], [u'Star Trek: Voyager', ''], [u'Star Wars: The Clone Wars', ''], [u'Suburgatory', ''], [u'Survivor', ''], [u'Survivorman', ''], [u'Switched at Birth', ''], [u'The Bachelor', ''], [u'The Bachelorette', ''], [u'The Bible', ''], [u'The Big Bang Theory', ''], [u'The Carrie Diaries', ''], [u'The Doctors Revisited', ''], [u'The Face', ''], [u'The Following', ''], [u'The Guild', ''], [u'The Mindy Project', ''], [u'The New Normal', ''], [u'The Newsroom (2012)', ''], [u'The Twilight Zone', ''], [u'The Universe', ''], [u"The Victoria's Secret Fashion Show", ''], [u'The Voice (US)', ''], [u'The Walking Dead', ''], [u'Top Gear', ''], [u'Torchwood', ''], [u'Tosh.0', ''], [u'True Blood', ''], [u'United States of Tara', ''], [u'Vikings', ''], [u'Warehouse 13', ''], [u'Weeds', ''], [u'2 Broke Girls', ''], [u'Airwolf', ''], [u"America's Next Top Model", ''], [u'American Horror Story', ''], [u'American Idol', ''], [u'Angel', ''], [u'Bates Motel', ''], [u'Battlestar Galactica (2003)', ''], [u'Beauty and the Beast (2012)', ''], [u'Behind The Music', ''], [u'Being Human (US)', ''], [u'Black Mirror', ''], [u'Blue Mountain State', ''], [u'Boardwalk Empire', ''], [u'Breaking Bad', ''], [u'Buck Rogers in the 25th Century', ''], [u'Buffy the Vampire Slayer', ''], [u'Community', ''], [u'Continuum', ''], [u'Copper', ''], [u'Cosmos', ''], [u'Cougar Town', ''], [u'Curiosity', ''], [u'Dancing With the Stars', ''], [u'Dark Matters', ''], [u'Deadliest Catch', ''], [u'Defiance', ''], [u'Desperate Housewives', ''], [u'Dexter', ''], [u'Dirty Jobs', ''], [u'Doctor Who', ''], [u'Doctor Who (2005)', ''], [u'Dollhouse', ''], [u"Don't Trust the B---- in Apartment 23", ''], [u'Downton Abbey', ''], [u'Drugs, Inc.', ''], [u'Elementary', ''], [u'Farscape', ''], [u'Fashion Police', ''], [u'Firefly', ''], [u'Formula 1', ''], [u'Fringe', ''], [u'Frontline (PBS)', ''], [u'Game of Thrones', ''], [u'Gangland', ''], [u'Girls', ''], [u'Glee', ''], [u'Go On', ''], [u"Grey's Anatomy", ''], [u'Grimm', ''], [u'Hannibal', ''], [u'Hemlock Grove', ''], [u'Homeland', ''], [u'House of Cards (US)', ''], [u'House of Lies', ''], [u'How I Met Your Mother', ''], [u"How It's Made", ''], [u'How Stuff Works', ''], [u'How The Universe Works', ''], [u'Into the Universe with Stephen Hawking', ''], [u"James May's Man Lab", ''], [u'Jem', ''], [u'King of the Nerds', ''], [u'Locked Up Abroad', ''], [u'Lost Girl', ''], [u'Mad Men', ''], [u'Maison close', ''], [u'Metal Hurlant Chronicles', ''], [u'Modern Family', ''], [u'Modern Marvels', ''], [u"MTV2's Guy Code", ''], [u'MythBusters', ''], [u'Nashville', ''], [u'New Girl', ''], [u'Nikita', ''], [u'NOVA', ''], [u'Nurse Jackie', ''], [u'Once Upon a Time (2011)', ''], [u'Orphan Black', ''], [u'Project Runway', ''], [u'Quantum Leap', ''], [u'Red Dwarf', ''], [u'Revolution', ''], [u'Sex and the City', ''], [u'Sherlock', ''], [u'Six Feet Under', ''], [u'Smash (2012)', ''], [u'Sons of Anarchy', ''], [u'South Park', ''], [u'Spartacus', ''], [u'Star Trek', ''], [u'Star Trek: Deep Space Nine', ''], [u'Star Trek: Enterprise', ''], [u'Star Trek: The Next Generation', ''], [u'Star Trek: Voyager', ''], [u'Star Wars: The Clone Wars', ''], [u'Suburgatory', ''], [u'Survivor', ''], [u'Survivorman', ''], [u'Switched at Birth', ''], [u'The Bachelor', ''], [u'The Bachelorette', ''], [u'The Bible', ''], [u'The Big Bang Theory', ''], [u'The Carrie Diaries', ''], [u'The Doctors Revisited', ''], [u'The Face', ''], [u'The Following', ''], [u'The Guild', ''], [u'The Mindy Project', ''], [u'The New Normal', ''], [u'The Newsroom (2012)', ''], [u'The Twilight Zone', ''], [u'The Universe', ''], [u"The Victoria's Secret Fashion Show", ''], [u'The Voice (US)', ''], [u'The Walking Dead', ''], [u'Top Gear', ''], [u'Torchwood', ''], [u'Tosh.0', ''], [u'True Blood', ''], [u'United States of Tara', ''], [u'Vikings', ''], [u'Warehouse 13', ''], [u'Weeds', ''], [u'2 Broke Girls', ''], [u'Airwolf', ''], [u"America's Next Top Model", ''], [u'American Horror Story', ''], [u'American Idol', ''], [u'Angel', ''], [u'Bates Motel', ''], [u'Battlestar Galactica (2003)', ''], [u'Beauty and the Beast (2012)', ''], [u'Behind The Music', ''], [u'Being Human (US)', ''], [u'Black Mirror', ''], [u'Blue Mountain State', ''], [u'Boardwalk Empire', ''], [u'Breaking Bad', ''], [u'Buck Rogers in the 25th Century', ''], [u'Buffy the Vampire Slayer', ''], [u'Community', ''], [u'Continuum', ''], [u'Copper', ''], [u'Cosmos', ''], [u'Cougar Town', ''], [u'Curiosity', ''], [u'Dancing With the Stars', ''], [u'Dark Matters', ''], [u'Deadliest Catch', ''], [u'Defiance', ''], [u'Desperate Housewives', ''], [u'Dexter', ''], [u'Dirty Jobs', ''], [u'Doctor Who', ''], [u'Doctor Who (2005)', ''], [u'Dollhouse', ''], [u"Don't Trust the B---- in Apartment 23", ''], [u'Downton Abbey', ''], [u'Drugs, Inc.', ''], [u'Elementary', ''], [u'Farscape', ''], [u'Fashion Police', ''], [u'Firefly', ''], [u'Formula 1', ''], [u'Fringe', ''], [u'Frontline (PBS)', ''], [u'Game of Thrones', ''], [u'Gangland', ''], [u'Girls', ''], [u'Glee', ''], [u'Go On', ''], [u"Grey's Anatomy", ''], [u'Grimm', ''], [u'Hannibal', ''], [u'Hemlock Grove', ''], [u'Homeland', ''], [u'House of Cards (US)', ''], [u'House of Lies', ''], [u'How I Met Your Mother', ''], [u"How It's Made", ''], [u'How Stuff Works', ''], [u'How The Universe Works', ''], [u'Into the Universe with Stephen Hawking', ''], [u"James May's Man Lab", ''], [u'Jem', ''], [u'King of the Nerds', ''], [u'Locked Up Abroad', ''], [u'Lost Girl', ''], [u'Mad Men', ''], [u'Maison close', ''], [u'Metal Hurlant Chronicles', ''], [u'Modern Family', ''], [u'Modern Marvels', ''], [u"MTV2's Guy Code", ''], [u'MythBusters', ''], [u'Nashville', ''], [u'New Girl', ''], [u'Nikita', ''], [u'NOVA', ''], [u'Nurse Jackie', ''], [u'Once Upon a Time (2011)', ''], [u'Orphan Black', ''], [u'Project Runway', ''], [u'Quantum Leap', ''], [u'Red Dwarf', ''], [u'Revolution', ''], [u'Sex and the City', ''], [u'Sherlock', ''], [u'Six Feet Under', ''], [u'Smash (2012)', ''], [u'Sons of Anarchy', ''], [u'South Park', ''], [u'Spartacus', ''], [u'Star Trek', ''], [u'Star Trek: Deep Space Nine', ''], [u'Star Trek: Enterprise', ''], [u'Star Trek: The Next Generation', ''], [u'Star Trek: Voyager', ''], [u'Star Wars: The Clone Wars', ''], [u'Suburgatory', ''], [u'Survivor', ''], [u'Survivorman', ''], [u'Switched at Birth', ''], [u'The Bachelor', ''], [u'The Bachelorette', ''], [u'The Bible', ''], [u'The Big Bang Theory', ''], [u'The Carrie Diaries', ''], [u'The Doctors Revisited', ''], [u'The Face', ''], [u'The Following', ''], [u'The Guild', ''], [u'The Mindy Project', ''], [u'The New Normal', ''], [u'The Newsroom (2012)', ''], [u'The Twilight Zone', ''], [u'The Universe', ''], [u"The Victoria's Secret Fashion Show", ''], [u'The Voice (US)', ''], [u'The Walking Dead', ''], [u'Top Gear', ''], [u'Torchwood', ''], [u'Tosh.0', ''], [u'True Blood', ''], [u'United States of Tara', ''], [u'Vikings', ''], [u'Warehouse 13', ''], [u'Weeds', '']]
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: found genres []
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: fillTVInfo return []
12:05:24 T:12948 DEBUG: script.pseudotv-FileAccess: trying to open C:\Users\Boots\AppData\Roaming\XBMC\userdata\addon_data\script.pseudotv\cache\generated\Network_CBS.xsp
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: getChannelName 1
12:05:24 T:12948 ERROR: script.pseudotv-ChannelList: Unable to locate the playlist for channel 4
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: runActions 8 on channel 4
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: clearPlaylistHistory
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: channel not valid, ignoring
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: runActions 16 on channel 4
12:05:24 T:12948 DEBUG: script.pseudotv-ChannelList: runActions 64 on channel 4
No channel_4.m3u exists.
My library has a mixture of local network media, XBMCFlix, Hulu and other XBMC.MyLibrary strms files. The CBS list contains local network media.
