What are the prerequisites? I have tvheadend installed in a server and I have xbmc+pvr installed in another htpc working. I have my test machine next to me and I want to try this plugin, do I need to install xbmc+PVR first. It would be nice to have a wiki or write up of how or what a first time user needs to properly configure this.
Or a one liner, In order to take advantage of this great plugin you first need to setup xbmc with the PVR client (xbmc+PVR), etc., etc..
DanVan Wrote:I keep getting the error
"no valid channel data found"
I am on the default settings
here is my buglog, help?
http://www.heypasteit.com/clip/XET
I'm getting the same error. Did you get yours fixed?
speed32219 Wrote:What are the prerequisites? I have tvheadend installed in a server and I have xbmc+pvr installed in another htpc working. I have my test machine next to me and I want to try this plugin, do I need to install xbmc+PVR first. It would be nice to have a wiki or write up of how or what a first time user needs to properly configure this.
I don't think you understand the functions of this add-on. This add-on uses the movies and tv shows in your library (files already on the hard drive) and smart playlists. It doesn't support live video streams so the PVR branch is not necessary.
Sranshaft Wrote:I don't think you understand the functions of this add-on. This add-on uses the movies and tv shows in your library (files already on the hard drive) and smart playlists. It doesn't support live video streams so the PVR branch is not necessary.
Thank you, you are right, I did not understand and that is why I was looking for a wiki on it. All the discussions of channels and epg's was confusing, hence my frustration.
DanVan and/or LupinSansei - Can you please go to the settings, system, debugging, and enable debug logging, then start PseudoTV. After it fails, can you please post the resultant log file? Thanks.
Edit: I just noticed that DanVan's log does have debug info if I scroll down a bit...I'll check it out.
Edit 2: It appears that you don't actually have any movies or TV shows scraped into your library. Do you have some?
script.pseudotv-ChannelList: found shows []
script.pseudotv-ChannelList: found genres []
you need 2 scrape to your tv/movie lib
Jason102 Wrote:DanVan and/or LupinSansei - Can you please go to the settings, system, debugging, and enable debug logging, then start PseudoTV. After it fails, can you please post the resultant log file? Thanks.
Sure, here's the log file.
Also I do have TV series and movies in my library
http://www.megaupload.com/?d=I3A44EV2
LupinSansei: The issue you're having is that you run on the newest Git version. You need to use the stable-pre version of PseudoTV for this to work. I am getting close to releasing this to mainstream so that those running Eden won't have to worry about this, but I need to finish a feature I'm working on first.
Have u tried creating your own channel's in the channel config. ?
OK ..
stay stable
Jason102 Wrote:LupinSansei: The issue you're having is that you run on the newest Git version. You need to use the stable-pre version of PseudoTV for this to work. I am getting close to releasing this to mainstream so that those running Eden won't have to worry about this, but I need to finish a feature I'm working on first.
Ah ok man. Thanks! I'll give that a shot.
*Edi* Where can I find the pre-stable version?
first post on thus thread..
select down 2 stable-pre,, copy/save... and (over-ride)/replace current addon.
lol...
[quote=Steveb]first post on thus thread..
2 old 4 this shiit
dushe ..Sounds good..cya.. "Kaboom!.. get ridok 1 prob,,,,man + 10"
Steveb Wrote:[quote=Steveb]first post on thus thread..
2 old 4 this shiit
Sorry man I don't see it. Just a link to the Repository lol
