2011-02-25, 00:16
2011-02-25, 00:42
yeah, but win deinterlacing with dxva is not working
i tested some sample files in linux sdtv, hdtv 1080i and all played very nice 50fps
with vdapu enabled ... so my hope is that this would be a nice combo
so lets see what time will bring
2011-03-15, 22:55
Margro, Thanks for the latest build, updated today and all is working, Is there any way to set the tv channel order to that in Media portal ?
2011-03-20, 10:00
Hi, also can confirm that it works so far, problems with deinterlacing and
bad pic quality on live tv but this seems to be hardware related.
(ion2 no proper drivers i guess, SDTV 50fps but still not smooth, HDTV 720p 50fps jerky, HDTV 1080i 25fps jerky)
thanks for the update
2011-03-29, 09:06
I have a strange problem:
Last week I installed the opdenkamp version on a XBMCfreak Lucid live version.
TV worked great with streaming and everything. Only yesterday I did a reinstall of the system and now streaming doesn't work and gives me an error.
Te Windows versions still works so I'm really confused.
I have a pasted log, so I hope anyone can help me.
http://paste.ubuntu.com/586764/
2011-03-29, 10:17
this looks like a problem with the (configuration of the) backend. did you install and configure the cam on the backend (probably acamd)?
edit: didn't read the "it works on windows" part. then I suspect that it is some bug in the add-on itself.
2011-03-29, 20:10
Djang Wrote:I have a strange problem:
The problem is that a recent code refactor commit (git rev 9c696e532a67da80eef548a387632950a4383613, dd 19-03-2011) from Dushmaniac broke the stream playback of the MediaPortal (ffmpeg) addon at the XBMC side (live TV using the PVR stream_url field is broken now).
It is not a bug in the addon itself. XBMC currently does not ask the addon at all to start the Live stream.
Yesterday, I finally found the exact problem. I'm currently working on a fix...
The current solution: use a version from before 19-03-2011.
2011-03-29, 21:06
Alright thats understandable.
Then my next question is: How can I install an older version on the Live version.
Is there a linux command that makes that possible, cuz I'm a huge noob on Linux.
2011-03-29, 21:53
margro Wrote:The problem is that a recent code refactor commit (git rev 9c696e532a67da80eef548a387632950a4383613, dd 19-03-2011) from Dushmaniac broke the stream playback of the MediaPortal (ffmpeg) addon at the XBMC side (live TV using the PVR stream_url field is broken now).sorry :-) I could have a look at fixing it, but I can't test it as I don't have an mptv backend around.
@Djang:
you'll have to build xbmc from source or use another ppa than mine, as I only got the new one on there.
2011-03-29, 22:05
dushmaniac Wrote:sorry :-) I could have a look at fixing it, but I can't test it as I don't have an mptv backend around.No problem . I've fixed the problem already on my machine. Next step is to to fetch all your recent changes, rebase the fix and test it. Something for tomorrow...
2011-03-31, 11:31
anyone may knows when mp tv support will be working again ?
2011-03-31, 15:20
alturismo Wrote:anyone may knows when mp tv support will be working again ?I've fixed the issue in my github repo. So, if you want, you can compile my master branch...
(https://github.com/margro)
Although Live TV is working again, some other things are still broken (e.g. channel icons) and/or untested for all recent changes like setting timers and the time offsets (for EPG and timers).
2011-03-31, 19:14
thanks for the info, roughly i 1st have to look into howto compile from master branch on linux,
just went through all this on windows cause i tested the deinterlace patch
as this was not so successful im back on ubuntu now for testing.
thanks again for all your efforts on PVR
2011-04-01, 19:44
ok, compiled from source and tv is back
thanks for the update, roughly playback quality still a mess here on ion2 platform, but thats a diff story
thanks again
thanks again
2011-04-02, 21:00
Did the same on my XBMC Live build.
TV works again, thanks allot for the fix
