2011-01-20, 19:12
I just can't seem to get it right.
The correct Video resolution for the projector using a PC.
PS3 & Xbox 360 Looks great. When Projector screen comes on it says 1080p.
My HTPC on the other hand is driving me crazy.
What is the ideal resolution to use for a HTPC setup for 16:9 ?
The Zbox doesn't natively support 1024 x 768, I tried to use PowerStrip app to add it. (Could someone send me their Powerstrip settings with same type of display?)
The projector has an option to go from 4:3 to 16:9 , but it loses clarity. Do I have to use this on the projector to get 16:9?
IS there a resolution from the Zbox chipset that would crop it coming out and going into the Projector?
I have used XBMC for XBOX for many years and Love it. I boots quick and just works..
Using a PC on the other hand is a roal pain in the A$$ for this noob..
Alright... I have dealt with this years ago and am now dealing with this frustration again with complete new hardware.
Specs:
* 16:9 (Wide Screen) 100" Pull down screen
* ViewSonic PJ551D Projector - 1024 x 768 Native -View 12" from screen
http://www.viewsonic.com/assets/007/5670.pdf
* Zbox Zbox HD-ID11 - Windows 7 64bit , using XBMC, Windows Media Center, PowerStrip
http://www.tweaktown.com/reviews/3497/zo...index.html
* Sony Amp with Audio/Video support, HDMI & Component inputs.
Have all sources going IN using Component, OUT using component to Projector (VGA).
* WiFi N+ Gigabit router
* HD Homerun tunner device (Connects to network and streams channels)
* ESata external Blue-Ray Lighton drive
Specs:
