Full Version: Spoof MAC adress
I've got IPTV, so I've got a setop box connected to my TV. Now I want to get rid of it, and use my HTPC with XBMC Live to work as setop box. Therefore, I need to spoof my MAC adress.
Anyone know how to do that?
Edit: I'm using XBMC Live Dharma.
Also, I found this:
Quote:sudo gedit /etc/network/interfaces
But commando gedit is not found
use
sudo nano /etc/network/interfaces
instead
It usually depends on if your network card supports it and allows it in the kernel, most of the time this is not the case.
