Is there a way to disable the text that shows up behind settings, movie, etc.? Such as when you can see the words appearance and skin behind when you scroll over "settings?"
W H A T ?
sorry I didn't understand
CrazyDesi Wrote:Is there a way to disable the text that shows up behind settings, movie, etc.? Such as when you can see the words appearance and skin behind when you scroll over "settings?"
Are you on an AppleTV 2 by any chance?
I have the same problem on AppleTV
This is a problem with the current xbmc build for atv. It will be addressed when it is updated.
If you are comfortable with a bit of terminal work there is a user built version of xbmc for iOS in the iOS sub forum which addresses this and a few other issues until an official release comes out.
As far as I know there is no way to disable the sub-menus in shade although I haven't used it much so others may be able to tell you different.
