When I bring up dialogvideoinfo and select "Get Thumb" or "Get Fanart", nothing is scraped. I can choose a local image but dont have the images loading up from tvdb anymore? ideas?
You didn't use xbmc too get the original meta data? And thus the extra available images didn't get scraped the first time it added it to the library
Also if you use a 3rd party manager and check off some option like "don't use urls for images" then all you'll have is local images...
Thanks guys. Is it not possible to make it scrape everytime to select "get thumb"? Soemtimes I want to see what new images are out there while I'm browsing?
igotdvds Wrote:Thanks guys. Is it not possible to make it scrape everytime to select "get thumb"? Soemtimes I want to see what new images are out there while I'm browsing?
You'll have to do a Refresh and then get thumb.
stoli Wrote:You'll have to do a Refresh and then get thumb.
And make sure you choose not to use local NFOs.
