2011-01-22, 20:15
Pages: 1 2
2011-01-22, 20:28
Can someone please sticky this thread?
2011-01-22, 20:39
Also how to Jailbreak http://support.firecore.com/entries/387605
2011-01-22, 21:06
Without providing direct links to any of the jailbreak apps, this is actually a pretty good source of info for all of the different iOS versions out there and the respective jailbreak apps.
Wikipedia Jailbreak Page
2011-01-22, 22:26
stoli Wrote:Without providing direct links to any of the jailbreak apps, this is actually a pretty good source of info for all of the different iOS versions out there and the respective jailbreak apps.
not a very good source when it lists bad info
last time i checked (just now), 4.2.1 is tethered boot on iphone4, etc where that wiki page lists it as untethered.
2011-01-22, 22:30
2011-01-23, 02:56
iLLNESS Wrote:not a very good source when it lists bad info
actually 4.2.1 IS untethered so long as you use your 4.2b3 shsh/blobs.
2011-01-23, 18:03
i installed it on atv2 os 4.0 with no problem and putting the oldest skin is also more navigable!
2011-01-23, 20:42
Open6l Wrote:actually 4.2.1 IS untethered so long as you use your 4.2b3 shsh/blobs.
which is currently experimental/beta and also not a full jailbreak (only peopl in the developers program are 'legally' allowed to be using it). its still misleading whichever way you put it.
2011-01-24, 02:22
2011-01-24, 08:52
Please add
http://forum.xbmc.org/showpost.php?p=699...stcount=44
Into the wiki.. it is necessary to install
2011-01-28, 07:44
iLLNESS Wrote:How to enable AC3/DTS passthrough
Installing Skins 1
Installing Skins 2
Thanks very helpful. Should be added to the FAQ
2011-01-29, 10:17
Please add
How to fix Timezone?
rm /private/var/db/timezone/localtime
ln -s /usr/share/zoneinfo/Europe/Berlin /private/var/db/timezone/localtime
2011-02-13, 06:13
I keep getting an error when trying to click the windows (SMB)... i believe it is (ERROR 2) and it wont let me search for my shared files. If I manually try to add a source, I type in my IP address, then the folder name that holds the movie files, then I get a timeout error back. I just cant seem to access my shared files at all. Am I doing something incorrectly?
EDIT: Im using an Apple TV 2g
2011-02-17, 23:56
mcgehee44 Wrote:I keep getting an error when trying to click the windows (SMB)... i believe it is (ERROR 2) and it wont let me search for my shared files. If I manually try to add a source, I type in my IP address, then the folder name that holds the movie files, then I get a timeout error back. I just cant seem to access my shared files at all. Am I doing something incorrectly?
I am having the same exact problem.
Help from anyone is appreciated!
Pages: 1 2
