I've been playing with the group options in xbmc. So i removed all channels from the "all channels" group. But i can't get it back. Is there an easy way to reset this?
press "C" while in the channels list, choose "show hidden channels" and re-add the ones you want to undelete.
or reset the pvr database in the settings. or choose "sync channelgroup with backends".
hi i have qbox 6920 dvb card and ubuntu 10.04 . i install xbmc & tvheadend according your gudie now i can see channels but speed change channel is very slow even slower from kaffeine player . do you know why ? how i increase speed change channel ?
known issue. has something to do with buffering changes. I might improve it again before the next ppa release when I got time. if not, I'll fix it in the release after the next one.
"it is done when it's done"
Hi
Why xbmc process/thread increases CPU load all the time ?
XBMC is in idle - just in Main menu - and CPU load starts from 6% (after restart) and constantly rising up to 100% and more (2 cores CPU). It takes abt. 20 minutes. From time to time, when it's abt. 100% it backs to 6% and then starts rising again.
Here is
log
BR
Janusz
looks like you're using an old build, because I can see a problem there that's been fixed over a week ago.
No change on the newest ver. 2:11.0-pvr+odk38~git20110521.09c02fa-0ubuntu1~ppa+odk38~lucid.
log
your backend is sending channel updates (changed names etc.) all the time, so xbmc is updating all channels (the update code isn't optimised yet, so this might take a bit longer than needed/expected)
janumix Wrote:Hi
Here is log
BR
Janusz
I had this problem before changing v-sync options in video settings.. try "let application decide" or somewhat
Lars, love your work, silly question, on the latest XBMC-Live (Dharma 10.1), tvheadend is already pre-installed, so following the instructions on the first page seems a bit redundant, what would it take to "just" install the xbmc-pvr branch ? (ie update the xbmc-live one for the pvr one so one can use the tvheadend add-on)
maybe this ??
sudo add-apt-repository ppa:lars-opdenkamp/xbmc-pvr
sudo apt-get -y install xbmc-live
Thx, sorry if this has been asked before but didn't want to read 55 pages and search didn't help.
the instructions in the first post are correct for xbmc-live too, since you'll have to upgrade tvheadend to be able to use all of xbmc's features. "apt-get install" actually means "install the package if you don't have it yet, or upgrade it if there is one available".
you also have to do an "apt-get update" after adding the ppa source, and the first line ("sudo apt-get install -y python-software-properties") just makes sure you actually have add-apt-repository installed.
so, the instructions are fine for xbmc-live.
Thanks, makes sense, rusty on the apt-get stuff as last time I used linux was slackware 8...
Just wanted to makes sure that this was fine for xbmc-live 10.1
bedankt
jack burton Wrote:I had this problem before changing v-sync options in video settings.. try "let application decide" or somewhat
Unfortunately it doesn't help.....
I checked all options ...
CPU load is abt. 6% during SD playback (or SD live TV). It rises when idle.
