dushmaniac Wrote:it's been fixed already. I'll push a new build later today containing the fix
Did you push only for i386? I made the mistake of installing x86_64 ubuntu on mine, and haven't had any update in the last week at least.
The last update indeed fixed the Addon problem. Thanks!
Guys, it has been mentioned in this thread how some people have tried to setup a grabber. But I haven't seen a definite solution. I have OTA and have tried using the DirecTV grabber for North America but it isn't populating. First...
Is the DirecTV the best option? If it works I guess it would be...
I issued the command...
# /usr/bin/tv_grab_na_dtv --configure
and entered my location settings, then right after Zip Code it gives...
"Select the channels that you want to receive data for."
and then goes back to prompt. So, I do have a different "User" entered into my "Access Control" called "DVR". I have NOT added another User in XBMC Live called DVR. Should I have setup TVheadend to use the same username as XBMC Live?
I am lost. Any help would be greatly appreciated to get my EPG working. Thanks.
hi
last update is great
thx dushmaniac
very nice
kojote
Hi.
First I want to thank you Dushmaniac, thanks to your great work I've finally gave away my dm800 PVR.
This has probably been noted, but lately I have to stop the tv stream when switching to Radio and vice versa.
Cheers.
Kjetil
Before I open these as new issues I just wanted to check if anybody else has experienced the following issues and has cured them...
1 - When switching to a channel for the first time in XBMC I am finding it is defaulting to the 2nd Audio track (usually has narration on it). I switch it back the 1st audio track and set as default for all movies. It doesn't actually set it for the other channels but does remember it for that single channel. If I reset the PVR database (or remove TV16.db & Epg5.db) then it defaults back to the 2nd audio track again.
2 - I have XBMC running on my server which is on 24/7. Overnight it seems to jumble some of the EPG allocation. Every morning I find the same 2 or 3 channels are now showing listings from other channels. Restarting XBMC or removing the DB files cures it, but it's annoying. I have also found this on my main XBMC machine that I put into standby overnight (same channels show the issue)
Thanks for the suggestion. I tried it and nothing different. It is funny, when I run...
# tv_grab_na_dtv --configure
I can go through the setup until I enter the zip code, I enter my zip code, and then get
and then it goes right back to the prompt. Shouldn't it continue with setup to select which channels I want to receive data from?
behaviour Wrote:Before I open these as new issues I just wanted to check if anybody else has experienced the following issues and has cured them...
behaviour,
I've noticed exatly the same, also some of the subtitle default to 2/2 instead of 1/2.
Cheers
Kjetil
does setting timers work in the tvheadend addon?
i am testing the myth addon and it segfaults when i try to set a timer and i cant figure out why.
dubstar_04 Wrote:does setting timers work in the tvheadend addon?
It does.
Hi
Some times when i start playing a move xbmc crashes.
I here sound but no picture and i cant stop playback...
no strange things in the logs, it thinks it´s playing fine...
it always happen after i have watched livetv for awhile...
Any one else sen this?
Okay, I tried the suggestion below and it didn't work.
LeeG Wrote:Dunno if it will help but have you tried following these instructions? http://forum.xbmc.org/showpost.php?p=773...tcount=373
When I run
It asks me to "Select the channels that you want to receive data for." But immediately after sends me to the prompt with the chance to add channels. What the....!?
#1 Anyone know if the DirecTV grabber is the right choice to use for OTA local channels?
#2 Anyone know of other options to add an EPG for OTA channels?
This is the result of "Save Configuration" in TVheadend which runs tv_grab_na_dtv.
"xmltv: /usr/bin/tv_grab_na_dtv: Parsing completed. XML contained 0 channels, 0 events, 0 new events injected in EPG"
I don't want to clutter this thread so if anyone has any thoughts on that don't hesitate to tell me to go elsewhere. Thanks.
In the latest builds does not work the volume up with plus button on the keyboard. But works shift+plus.
