I've set up a fresh installation of Ubuntu Minimal, XBMC PVR, with tvheadend and oscam. I'm currently using the XBMC PVR branch, but I'd like to use the XBMC Expirimental branch to get updates more regularly.
Secondly... It does not seem to be possible to record from XBMC on TVheadend. When I try to I get a error referring to the backend log. Recording from the webinterface works fine.
After some troubles I've figured out how to configure oscam and tvheadend to play all my Ziggo channels. Using a Anysee E30C Plus receiver and separate card reader (since the Anysee cardreader doesn't seem to be supported by the linux kernel yet). This wasn't easy but it's working now
I can't record, I can't timeshift which must be the reason why I can't pause the TV stream. I can't stream the TV signal via the web interface (results in a error).
Unfortunately MythTV doesn't support softcam usage (as far as I've been able to figure out). Otherwise that would probably be the better option for me.
Maybe someone has some answers for me, since I'm new to using XBMC as a PVR solution...
- TVheadend does not always start playing the requested channel. It seems to keep trying but playback never starts (sometimes). Is there any way I can make this functionality more reliable?
- Would it be possible to install some addon's in XBMC from the expirimental ppa to support TVheadend the same way the PVR branch does and if so, where can I find them?
- Can anyone tell me what could be causing the error in XBMC that prevents recording from the XBMC interface?
- Is there any way to enable time-shift or are there plans to add this feature in the near future?
- Will tvheadend be able to record two channels with one tuner in the near future (like MythTV can)?
- What can I do to allow streaming TV via the web interface?
Worst case scenario I would be willing to go and use XBMC for Windows combined with the MediaPortal TV-server (beautiful piece of software). Which would mean installing windows for the first time in 6 years. This would not be my first choice but it might render the hardware investments useful. Would it be possible to use the MediaPortal PVR client for XBMC in Windows and if so, where can I get it?
