ocram Wrote:I have been testing the past week tvheadend + XBMC, and overal it's quite good, fast channel switching, a year ago I was using MediaPortal on Windows and a channel switch could take almost 5 seconds or more, so in that regard it's quite good. I even switched to an VUDUO for that annoyance, but am trying xbmc pvr right now for the eye candy.
The problem, when the pc was idle and I tune to a channel on 12722 H astra 19.2 from TVVlaanderen(2BE,VTM,een,...), it wil fail, actually tvheadend fails, XBMC says "no input deteced", tvheadend says "no signal" or "graceperiod expired", if I tune to another transponder It will work, changing back to the TVVlaanderen transponder it will work also.
DVB-S2 card is TBS-6922. OS: Ubuntu 11.04
The pc is on 24/7, so no standby, running latest XBMC from pulse ppa and tvheadend from github compiled yesterday. If it works the quality is normal, the VUDUO is currently connected to the same sattelite on the second LNB output, and also no problem, so signal quality from the dish is OK. The disecq switching works also.
Does anybody have an idea how to troubleshoot this? The debug output on the webui isn't very useful, and how can I let tvheadend log debug information in syslog instead of the basic info, because I can't sit in front of the webui all day.
P.S.: a few posts back I saw some problems with a crash, try deleting epgdb in /home/hts/.hts/tvheadend, was having the same problem, this solved it. Was running latest version from pulse ppa at that time.
Just to let anybody know who has the same problems as I did, after 2 weeks of testing tvheadend, I couldn't get it working, sometimes it worked sometimes it didn't, at the end it couldn't even add channels, because it wouldn't lock on any service, I did some testing with scan-s2 and szap-s2, both worked great.
Eventually I tried installing vdr, but after an hour I gave up, next day tried again, finally got it working (compiled and running), still no picture... removed everything, next day because tvheadend messed up again and some more reading I realized that my diseqc settings in vdr where wrong, so I installed vdr for a 3rd time.
And finally I have a picture... It wasn't easy trying to understand the whole compile routine from vdr with the plugins, but once I understood, it's quite easy.
So the end result is:
tvheadend running for +/- 10 days perhaps more, 3 succesful recordings instead of 10+.
vdr running for 4 days, gives 4 succesful recordings and 4332 channels working flawless, it has been rock solid, no messing with xmltv all the epg comes in with the signal, very advanced autotimer possibility's, but it took me 3days to install, figuring everything out, what plugins to use,....
But how come I don't read these problems on the internet? What is tvheadend doing differently from those 3 other programs, or at least try's to do, because with my setup it fails? And if I read all the other experiences al lot of people seem to have it running pretty well, or am I making the wrong conclusions here?
