Full Version: Scraping TV
This is not really a problem, but maybe it's a suggestion/question.
I have Folders with Series Name. In that folder I put the episodes, and if I have the episode number in the file name, all works well.
However, a lot of times, the download doesn't have the episode number, so I have to manually fnd out and add. But the name of the episode is in the file name in full. However, XBMC doesn't know which episode it is unless the episode number is there! Although it knows the series correctly from the folder name.
So, can we change the regular expression to check for the episode number in that series, and if not there, and there is a match on the episode name, why not just match it and add it?
Thanks Smile
