2011-01-25, 05:54
2011-01-25, 07:23
js72 Wrote:Hi all
Will xbox (original) recognise external hard drive plugged in direct rather than via a pc?
Thanks in advance
JS
for all your xbox question you can go here bro, as xbox is not supported here anymore.
Link: http://www.xbmc4xbox.org/
2011-01-25, 13:08
Only up to 4Gb - ie a memory stick. Internally up to 2TB can be installed. But NAS is by far the best thing to use.
But yep get over to xbmc4xbox - good bunch over there
