Full Version: [Linux] XBMC not use my LIRC settings every time
i have a hid, remote, recognized as keyboard, but works finde with lirc. the problem is, that xbmc loads many times the keyboard settings, but my remote fully works only with lirc. the problem is: i do not understand, why xbmc not use every time the lirc key settings. yesterday it works it works with lirc. after reboot, he used the keyboard settings, and i cant switch back.
irw:
xbmc@mediapc:~/.xbmc/temp$ irw
0000000000010160 00 OK Geniatech
0000000000010067 00 UP Geniatech
lircd.conf
link to my conf:
http://home.arcor.de/schenkenberger/lircd.txt
Lircmap.xml
<lircmap>
        <remote device="Geniatech">
                <left>LEFT</left>
                <right>RIGHT</right>
                <up>UP</up>
                <down>DOWN</down>
                <select>OK</select>
                <display>EPG</display>
        </remote>
</lircmap>
a part of my xbmc.log
13:27:11 T:139817941669920 M:1843261440   DEBUG: OnKey: 61477 pressed, action is Left
13:26:57 T:139817941669920 M:1879683072    INFO: load keymapping
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/keymaps/gamepad.xml
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/keymaps/joystick.Alienware.Dual.Compatible.Controller.xml
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/keymaps/joystick.AppleRemote.xml
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/keymaps/joystick.Harmony.xml
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/keymaps/joystick.Interact.AxisPad.xml
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/keymaps/joystick.Logitech.RumblePad.2.xml
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.360.Controller.xml
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.Controller.S.xml
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/keymaps/joystick.PS3.Remote.Keyboard.xml
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/keymaps/joystick.Sony.PLAYSTATION(R)3.Controller.xml
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/keymaps/joystick.WiiRemote.xml
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/keymaps/keyboard.xml
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/keymaps/remote.xml
13:26:57 T:139817941669920 M:1879683072   ERROR: Keymapping error: no such action 'language' defined
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://xbmc/system/Lircmap.xml
13:26:57 T:139817941669920 M:1879683072    INFO: * Adding remote mapping for device 'mceusb'
13:26:57 T:139817941669920 M:1879683072    INFO: * Adding remote mapping for device 'XboxDVDDongle'
13:26:57 T:139817941669920 M:1879683072    INFO: * Adding remote mapping for device 'Microsoft_Xbox'
13:26:57 T:139817941669920 M:1879683072    INFO: * Adding remote mapping for device 'PinnacleSysPCTVRemote'
13:26:57 T:139817941669920 M:1879683072    INFO: * Adding remote mapping for device 'anysee'
13:26:57 T:139817941669920 M:1879683072    INFO: * Adding remote mapping for device 'iMON-PAD'
13:26:57 T:139817941669920 M:1879683072    INFO: * Adding remote mapping for device 'Antec_Veris_RM200'
13:26:57 T:139817941669920 M:1879683072    INFO: * Adding remote mapping for device 'MCE_via_iMON'
13:26:57 T:139817941669920 M:1879683072    INFO: * Adding remote mapping for device 'TwinHanRemote'
13:26:57 T:139817941669920 M:1879683072    INFO: * Adding remote mapping for device 'linux-input-layer'
13:26:57 T:139817941669920 M:1879683072    INFO: Loading special://profile/Lircmap.xml
13:26:57 T:139817941669920 M:1879683072    INFO: * Adding remote mapping for device 'Geniatech'
edit: everything i do, i cant bring up my remote back to work. xbmc use everytime the keyboard and let my remote work aus a keyboard Sad i changed nothing since yesterday. after the reboot tonight, the remote does not work
ok
i used this guide to reconfigure my settings:
http://forum.xbmc.org/showthread.php?tid=63484
after this my remote worked again, but after restart i have the same problems as before Sad
ok i found the problem. if is start the pc. i must restart lirc xbmc 2 times. is there a any way to fix this?
