Does anyone know if there is a keyboard shortcut to delete a file rather than right clicking on it and selecting delete?
pbusardo Wrote:Does anyone know if there is a keyboard shortcut to delete a file rather than right clicking on it and selecting delete?
Have you tried the button "Delete"?
watzen Wrote:Have you tried the button "Delete"?
Yes, I did. Thanks for the valuable input.
Eh, for me, delete really deletes.
watzen Wrote:Eh, for me, delete really deletes.
Interesting. Doesn't work for me.
Doesn'twork for me either
The Delete key is mapped to the Delete action in various windows but not all. Whether the Delete key will do anything depends on where you're trying to use it.
JR
is there possibility to delete library entry with corresponding files ? to avoid readd with next auto scan?
if you enable it in settings; yes.
I i cant delete files by clicking [del]
nor can i select its folder by clicking [space]
but i can go to its folder clicking [c] then there is pop up with
Edit source - Make default - Remove source - Choose thumbnail
hope it can help
i am using Kodi 16.1 on android kitkat 4.4.4
Help? This thread is over 6 years old!
