2012-02-23, 19:22
2012-02-24, 09:44
@cosmicr
i have updated to xbmc eden beta3. I´m using openelec latest beta and i become this error in debug log:
08:37:01 T:2951740224 NOTICE: -->Python Interpreter Initialized<--
08:37:01 T:2951740224 DEBUG: Process - The source file to load is /storage/.xbmc/addons/script.imdbratings/default.py
08:37:01 T:2951740224 DEBUG: Process - Setting the Python path to /storage/.xbmc/addons/script.imdbratings:/usr/share/xbmc/addons/script.module.simplejson/lib:/usr/share/xbmc/addons/script.module.pil/lib:/storage/.xbmc/addons/script.module.elementtree/lib:/usr/lib/python2.7/site-packages/distribute-0.6.24-py2.7.egg:/usr/lib/python2.7/site-packages/simplejson-2.1.6-py2.7-linux-i686.egg:/usr/lib/python2.7/site-packages/configobj-4.7.2-py2.7.egg:/usr/lib/python27.zip:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/lib/python2.7/site-packages:/usr/lib/python2.7/site-packages/PIL:/usr/lib/python2.7/site-packages/gtk-2.0:
08:37:01 T:2951740224 DEBUG: Process - Entering source directory /storage/.xbmc/addons/script.imdbratings
08:37:01 T:2951740224 DEBUG: Instantiating addon using automatically obtained id of "script.imdbratings" dependent on version 1.0 of the xbmc.python api
08:37:03 T:2951740224 NOTICE: IMDB Rating Script: Database type is set to SQLite
08:37:03 T:2951740224 INFO: -->Python script returned the following error<--
08:37:03 T:2951740224 ERROR: Error Type: <type 'exceptions.ImportError'>
08:37:03 T:2951740224 ERROR: Error Contents: libmysqlclient_r.so.16: cannot open shared object file: No such file or directory
08:37:03 T:2951740224 ERROR: Traceback (most recent call last):
File "/storage/.xbmc/addons/script.imdbratings/default.py", line 61, in <module>
import MySQLdb as mdb
File "/storage/.xbmc/addons/script.imdbratings/resources/lib/MySQLdb/__init__.py", line 19, in <module>
import _mysql
ImportError: libmysqlclient_r.so.16: cannot open shared object file: No such file or directory
08:37:03 T:2951740224 INFO: -->End of Python script error report<--
@frumpsnake
this addon renew the ratings from movies which are in your libary. The Get Movie from function is for first scan only. But the ratings change from day to day.
Greets
Eisi
import _mysql
@frumpsnake
Greets
Eisi
2012-02-28, 23:26
@cosmicr
could you take a look at my log files ? Post before this is from a linux os with xbmc b3 and this logfile is from win7 with xbmc b3. Something is wrong with getting the database.
22:21:31 T:7132 INFO: -->Python script returned the following error<--
22:21:31 T:7132 ERROR: Error Type: <type 'exceptions.ValueError'>
22:21:31 T:7132 ERROR: Error Contents: invalid literal for int() with base 10: 'SQLite'
22:21:31 T:7132 ERROR: Traceback (most recent call last):
File "C:\Users\AdminEisi2005\AppData\Roaming\XBMC\addons\script.imdbratings\default.py", line 46, in <module>
MySQL = int(Addon.getSetting("database"))
ValueError: invalid literal for int() with base 10: 'SQLite'
22:21:31 T:7132 INFO: -->End of Python script error report<--
22:21:31 T:7132 INFO: Python script stopped
Greets
Eisi
Greets
Eisi
2012-03-02, 00:22
Hi Eisi2005, I'm not 100% sure but it appears I may have made a mistake in getting settings from the config file. I'm assuming others may have had this problem too, I'll look into it and try to get an update posted in the next day or so.
I didn't do a lot of testing on other systems, all I know is it worked on my machine
I've got a few machines so I'll test it a bit more thoroughly...
@frumpsnake:
Two reasons, when I started this addon the inbuilt scraper only got the rating from themoviedb, but now this addon is useful to update an already existing library.
@frumpsnake:
2012-03-02, 08:51
@cosmicr
thx for working on it.
If you need someone to test, gibe me the files to change and i will test it for you.
I have one win7 64 bit with b3 and one linux (openelec) with b3.
Greets
Eisi
Greets
Eisi
2012-03-08, 13:38
@cosmicr
i don´t wont to nerv you, but is there anything i could do to test myself in your settings. something that i put the directory to my database manuel ?
Greets
Eisi
Greets
Eisi
2012-04-28, 19:33
Yeah, I get a similar error:
I'm not using MySQL.
14:30:31 T:3760 NOTICE: -->Python Interpreter Initialized<--
14:30:32 T:3760 NOTICE: Service: 4804 actors took 0.35500001907348633
14:30:55 T:7324 ERROR: Control 1 in window 10099 has been asked to focus, but it can't
14:31:09 T:6440 WARNING: XFILE::CFileFactory::CreateLoader - Unsupported protocol(addons) in addons://more/executable.tbn
14:31:11 T:7332 NOTICE: -->Python Interpreter Initialized<--
14:31:11 T:7332 NOTICE: IMDB Rating Script: Database type is set to SQLite
14:31:11 T:7332 ERROR: Error Type: <type 'exceptions.ImportError'>
14:31:11 T:7332 ERROR: Error Contents: No module named _mysql
14:31:11 T:7332 ERROR: Traceback (most recent call last):
File "C:\XBMC\portable_data\addons\script.imdbratings\default.py", line 61, in <module>
File "C:\XBMC\portable_data\addons\script.imdbratings\resources/lib\MySQLdb\__init__.py", line 19, in <module>
import _mysql
ImportError: No module named _mysql
2012-04-28, 23:54
hi all, sorry I disappeared off the face of the earth, but I have been very busy with other things.
I don't have time to fix the problem, but it looks like I got too hasty in testing mysql and stuffed up the check between sqlite and mysql at the start (so it's always trying mysql even if you have sqlite).
If someone wants to fix it, check the source on my git page, it shouldn't take too much to fix.
2012-07-06, 00:26
Hey nice Script,
probably i found a Bug.
I don't know why, but some movies in my database have a wrong IMDBID.
for example:
Armored have a numeric ID 0913354 but need that ID tt0913354
The Script fails to open the wrong IMDB Site : http://www.imdb.com/title/0913354/
It is possible to add in your Code a ID Check like that:
If 'tt' in num:
Try Base_URL + num
else:
Base_URL + "tt" + num
Sorry I'm a python newbie my language is VBScript..
This is not my Solution to solve my IMDBID Problem in my database but it makes the script run.
or
It's a remote possibility to help me to change all wrong IMDBID in my Database...
for example:
If 'tt' in num:
Try Base_URL + num
else:
or
2012-07-06, 05:26
(2012-04-28, 23:54)cosmicr Wrote: [ -> ]hi all, sorry I disappeared off the face of the earth, but I have been very busy with other things.
Respect !! life happens. thanks for telling us.
for the record, i am using mySQL and it seems borked too
is it telling me to levelUP my elves ?
23:12:26 T:139800489211648 INFO: -->Python script returned the following error<--
23:12:26 T:139800489211648 ERROR: Error Type: <type 'exceptions.ImportError'>
23:12:26 T:139800489211648 ERROR: Error Contents: /home/zosky/.xbmc/addons/script.imdbratings/resources/lib/_mysql.so: wrong ELF class: ELFCLASS32
23:12:26 T:139800489211648 ERROR: Traceback (most recent call last):
File "/home/zosky/.xbmc/addons/script.imdbratings/default.py", line 61, in <module>
File "/home/zosky/.xbmc/addons/script.imdbratings/resources/lib/MySQLdb/__init__.py", line 19, in <module>
import _mysql
ImportError: /home/zosky/.xbmc/addons/script.imdbratings/resources/lib/_mysql.so: wrong ELF class: ELFCLASS32
23:12:26 T:139800489211648 INFO: -->End of Python script error report<--
23:12:26 T:139800489211648 INFO: Python script stopped
2012-07-06, 17:20
(2012-07-06, 00:26)dvbtjunkie Wrote: [ -> ]Hey nice Script,
for example:
If 'tt' in num:
Try Base_URL + num
else:
or
Database problem solved:
Edit with SQLLiteExplorer : http://wiki.xbmc.org/index.php?title=HOW...base-files
Statement: UPDATE movie SET c09 = "tt" || c09 WHERE c09 not like 'tt%';
2012-07-20, 15:07
I get error and script failed !!!
debug :
any idea how to slove this error ?
debug :
17:33:42 T:2595224384 NOTICE: -->Python Interpreter Initialized<--
17:33:42 T:2595224384 DEBUG: Process - The source file to load is /home/payam/.xbmc/addons/script.imdbratings/default.py
17:33:42 T:2595224384 DEBUG: Process - Setting the Python path to /home/payam/.xbmc/addons/script.imdbratings:/home/payam/.xbmc/addons/script.module.xbmcswift/lib:/home/payam/.xbmc/addons/script.module.simplejson/lib:/home/payam/.xbmc/addons/script.module.myconnpy/lib:/home/payam/.xbmc/addons/script.module.beautifulsoup/lib:/usr/share/xbmc/addons/script.module.pil/lib:/home/payam/.xbmc/addons/script.common.plugin.cache/lib:/home/payam/.xbmc/addons/script.module.simple.downloader/lib:/home/payam/.xbmc/addons/script.module.parsedom/lib:/home/payam/.xbmc/addons/script.module.elementtree/lib:/usr/share/xbmc/addons/script.module.pysqlite/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PIL:/usr/lib/python2.7/dist-packages/gst-0.10:/usr/lib/python2.7/dist-packages/gtk-2.0:/usr/lib/pymodules/python2.7:/usr/lib/python2.7/dist-packages/ubuntu-sso-client:/usr/lib/python2.7/dist-packages/ubuntuone-client:/usr/lib/python2.7/dist-packages/ubuntuone-control-panel:/usr/lib/python2.7/dist-packages/ubuntuone-couch:/usr/lib/python2.7/dist-packages/ubuntuone-installer:/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol:/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode:
17:33:42 T:2595224384 DEBUG: Process - Entering source directory /home/payam/.xbmc/addons/script.imdbratings
17:33:42 T:2595224384 DEBUG: Instantiating addon using automatically obtained id of "script.imdbratings" dependent on version 1.0 of the xbmc.python api
17:33:42 T:2595224384 NOTICE: IMDB Rating Script: Database type is set to MySQL
17:33:42 T:2595224384 NOTICE: IMDB Rating Script: MySQL Server Address is 192.168.1.14
17:33:42 T:2595224384 INFO: Loading skin file: DialogYesNo.xml
17:33:42 T:3015259904 DEBUG: ------ Window Init (DialogYesNo.xml) ------
17:33:42 T:3015259904 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
17:33:45 T:2682678080 DEBUG: JSONRPC Server: New connection detected
17:33:45 T:2682678080 INFO: JSONRPC Server: New connection added
17:33:53 T:3015259904 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
17:33:53 T:3015259904 DEBUG: SDLKeyboard: scancode: 71, sym: 0114, unicode: 0000, modifier: 1000
17:33:53 T:3015259904 DEBUG: OnKey: left (f082) pressed, action is Left
17:33:54 T:3015259904 DEBUG: SDLKeyboard: scancode: 24, sym: 000d, unicode: 000d, modifier: 1000
17:33:54 T:3015259904 DEBUG: OnKey: return (f00d) pressed, action is Select
17:33:54 T:3015259904 DEBUG: ------ Window Deinit (DialogYesNo.xml) ------
17:33:54 T:2595224384 INFO: -->Python script returned the following error<--
17:33:54 T:2595224384 ERROR: Error Type: <type 'exceptions.ImportError'>
17:33:54 T:2595224384 ERROR: Error Contents: libmysqlclient_r.so.16: cannot open shared object file: No such file or directory
17:33:54 T:2595224384 ERROR: Traceback (most recent call last):
File "/home/payam/.xbmc/addons/script.imdbratings/default.py", line 61, in <module>
File "/home/payam/.xbmc/addons/script.imdbratings/resources/lib/MySQLdb/__init__.py", line 19, in <module>
import _mysql
17:33:54 T:2595224384 INFO: -->End of Python script error report<--
17:33:54 T:2595224384 INFO: Python script stopped
2013-02-26, 02:52
@ cosmicr
i love your script,
it is possible to get a upgrade to Frodo?
After Upgrade my XBMC to Frodo, it is impossible to install
Thx a lot
i love your script,
Thx a lot
2013-04-10, 15:36
I've written a small .net app that refreshes the IMDB score in XBMC by scraping the IMDB site directly. It works with Frodo and either the local SQLite database or the shared MySQL library. Here's the link:
https://bitbucket.org/sstanford/imdb-sco...c/overview
It's only for the films I'm afraid. It also doesnt update the .nfo files - but these can be updated by exporting the video library in XBMC and overwriting in the normal way.
