Hi all, sorry once again for neglecting this addon. I'll be updating soonish to use the JSON-RPC API instead of direct read/writes to the database, as well as using a different imdb api (instead of hammering their site).
I'm also planning on getting this addon in to the official repository.
Stay Tuned.
How can I do for add the script in frodo 12.2 ? thanks
I've made the updates, the addon is working for Frodo, but I haven't had the time to post an update. I just need to push it to git, and I'll have a link soon.
Big Thx...
Unfortunately it gives a error,
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: integer argument expected, got float
File "/home/xbmc/.xbmc/addons/script.imdbratings/default.py", line 131, in <module>
main()
File "/home/xbmc/.xbmc/addons/script.imdbratings/default.py", line 115, in main
pDialog.update(percent,_('beginning_update'),movie['label'],_('rating')+rating)
TypeError: integer argument expected, got float
hmm that's weird. I'm not sure why it's doing that - I never ran into that error. An easy fix - I will fix it and update as soon as I can. Thanks for letting me know.
Hi man, thanks!
I was wondering, could this be modified to get the mpaa descriptions added to movies? Theres a similar script here and I tried modifying that one but it was too hard. This one looks like it might be a bit easyer to do?
I just need it to run once to add the mpaa description to 900 movies. Thanks for any help, and thanks for the addon
EDIT: Not sure this matters but in the Default.py you have:
command='{"jsonrpc": "2.0", "method": "VideoLibrary.SetMovieDetails", "params": { "movieid" : ' + movieid + ', "rating" : '+ rating + ', "votes" : "' + votes + '"}, "id": 2}'
Note:
Theres a missing space between the ' and + rating + '
Like I said I have no idea if that matters or not but noticed it while I was attempting to modify this to add the mpaa descriptions and thought Id mention it.
@ cosmicr
Any ideas to fix the Problem?
(2013-06-18, 00:05)dvbtjunkie Wrote: [ -> ]@ cosmicr
change this line in default.py:
to
pDialog.update(int(percent),_('beginning_update'),movie['label'],_('rating')+rating)
(2013-06-18, 08:58)Jandalf Wrote: [ -> ] (2013-06-18, 00:05)dvbtjunkie Wrote: [ -> ]@ cosmicr
to
@ Jandalf
OMG, only a convert to Integer.... Thx a lot
Now it works fine...
I keep getting "Script Failed" message in OpenELEC but it works in Windows. Any ideas?
Shedrock
(2013-06-21, 01:25)shedrock Wrote: [ -> ]I keep getting "Script Failed" message in OpenELEC but it works in Windows. Any ideas?
Shedrock
pls post your log from openelec
(2013-06-21, 15:07)shedrock Wrote: [ -> ]Here is the log:
http://xbmclogs.com/show.php?id=30288
same problem as above:
(2013-06-18, 08:58)Jandalf Wrote: [ -> ]change this line in default.py:
to
don't know why this only happens in openelec, do you have a different amount of movies?
