Full Version: Auto Movie Downloader - based on IMDB criteria
Hi guys. I would like to introduce the good work of binhex who posted his work on SABnzbd forums.
The program is Auto Movie Downloader.
This monitors nzbmatrix/nzbs for releases, it then checks imdb for certain criteria, if there is a positive match then it will download the nzb to either a queued folder or to the defined "watched" folder for sabnzbd+ to download.
feature list
checks for existing movies
define genres
define min rating
define min votes
define min year
define favorite actors
define favorite directors
define favorite characters
define favorite movie titles
define ignore titles
define ignore genres
define prefered genres and rating
define queue genres (used for genres you may or may not want)
define queue year (can be used for early movies you may or may not want)
download coverart for movie
download trailer for movie
create metadata for movie browser (media center plugin)
email notification of queued and downloading jobs
min download size to accept
title value filtering e.g telesync, telecine etc.
I would say I'm very happy with that script that run in Dos Command every 1 hour (task created in Windows 7)
It can be downloaded here : http://www.mediafire.com/?0zdu5dyz9h3bbh9
changelog
ver 1.3.3
- changed sd and hd folder variable names in config.ini to reflect their functions and added in ability to disable/enable
- new feature added in ability to save trailers of queued/downloaded movies to user defined location and define resolution of trailer (specified in config.ini)
- added in ability to enable/disable favorites section in config.ini
Original post on SABnzbd forums : http://forums.sabnzbd.org/index.php?topic=4145.0
