Full Version: TVHeadEnd on Windows
I'm using those prebuilt versions from
http://www.scintilla.utwente.nl/~marcelg...build.html
for the TVHeadEnd Backend.
Since build from 27-11-2010 it does not show any TV Channels to me.
Radio Channels are there just fine and my manually added TVHeadEnd Video Source if working fine too.
Those builds are from https://github.com/margro/xbmc-antiquate...Dharma-pvr which is a fork of https://github.com/opdenkamp/xbmc-antiquated.
So can anybody tell me if:
- this is the right place for questions?
- where I can find the source of those addons to have a look in there myself?
Sorry, but I'm bit confused due to all the resturcturing currently taking place Wink
greetz
Croaker
Croaker Wrote:- this is the right place for questions?
http://forum.xbmc.org/showthread.php?tid=91716
Quote:- where I can find the source of those addons to have a look in there myself?
you just linked it yourself, although it's the old tree.
Dharma-pvr (as stable as it currently get): https://github.com/opdenkamp/xbmc/tree/Dharma
master (development): https://github.com/opdenkamp/xbmc
Thanks for the forum link, it's titled 'Linux' so I was missing this.
For the other: Hoped to get a hint where in the code I'd find the TVHeadEnd Client related stuff. Wasnt lucky until now Sad
https://github.com/opdenkamp/xbmc/tree/D.../tvheadend
though I wonder what you're going to do with it if you can't find that out by yourself.
Thank you...just did not see it...i could BET it wasnt there last time a searched.
I wouldn't bet on that if I were you ;-)
Same Problem here Sad
really annoying
Same problem here...
But working great on Linux... except it won't show my HD channels which are in H264 (Probably mpeg4)... Any ideas why that is?
if you compile the Dharma-pvr branch from source on Windows, you won't have that problem. I don't have the license to distribute Windows binaries, so I can't build it for you.
