Gotcha007 Wrote:Ok already corrected errors with image files
Change log 0.5.4b
I'm using 0.5.4b but still got the Icon01.jpg error twice, once a few seconds after startup, the second a few seconds after that. The icon next to Nzbs and NZBsu connection shows as ? rather than a cross or tick.
I also noticed 2 messages in the console window (didn't look before, sorry):
Exception in thread Thread-4:
File "threading.pyc", line 530, in __bootstrap_inner
File "CrazyBeaver.py", line 1754, in run
File "CrazyBeaver.py", line 887, in CheckConnection
File "wx\_core.pyc", line 3545, in ConvertToBitmap
PyAssertionError: C++ assertion "image.Ok()" failed at ..\..\src\msw\bitmap.cpp(
826) in wxBitmap::CreateFromImage(): invalid image
Exception in thread Thread-3:
Gotcha007 Wrote:Can you tell me what you have in your console log (you have to put the debug to yes in config.ini)
I set ConsoleLogToFile="yes", I assume this is the option you need? The file is pretty long, so I'll email it across.
