Full Version: Change focus of startup menu item
Is it possible to change to focus of the startup menu item (selected item when you start up XBMC) to the first item? Now it selects Weather and I want it to default select Movies.
Which file to modify and what?
It's always going to focus the 3rd in the List...
If using Vertical Home it's Home.xml
If using Horizontal Home it's Includes_HorizontalHome.xml
Search for id="3" and make it 3rd in the <content> list
Excellent, thanks!Laugh
