2011-01-28, 07:09
2011-01-29, 05:41
Try the Qualar and MikoToBuild mods. They are both working fine for me on the ATV2, it just takes a little time for XBMC to pick them up after you do the install.
2011-01-29, 15:35
thx, it's work
2011-04-03, 00:19
i'm trying to install rapier to my pc with windows 7 and it won't install. i tried adding it through the install with a zip file function but it just does nothing. i see no install progress or indication of it having problems installing. it just backs out from the window i was in and show no added skin. i also restarted xbmc to see if that would solve the problem but it hasn't. why is it not working?
2011-04-03, 00:47
because Rapier is not compatible with xbmc dharma 10.1
as mentioned above, you could try the Qualar and MikoToBuild mods of Rapier.
