Full Version: Current weather not working on Home Icon
I'm trying to get current weather working in the same way as in the original Alaska where you got a temperature reading by the clock in the top right corner.
I've activated the "Show current weather conditions" under "Home options" but I can not get it to work. If I enter "Weather" from the home menu I get correct readings.
Using Revisited 2.6.6 with Dharma 10.0 and have set "Home menu" to use icons.
Hey! What "Show current weather conditions" does is show the temperature in the default home page in the weather box. If you want the reading added by the clock, you can do something like this:
In the 720p/Includes.xml file look for $INFO[System.Time(hh:mm)]. There should be 3 labels matching this. Find the one matching your settings and add to it:
[COLOR TimeAMPM]$INFO[Weather.Temperature][/COLOR]
That should do the trick.
