Full Version: Editing the config files
Ok s I haven't messed with XBMC since it was on the original Xbox. Back then you could FTP into it and grab the config files to edit then reupload to avoid having to add sources and what not via the remote. Is that possible on the ATV? If so are there any quick steps or pointers? I tried to root around a bit with SSH but find only apple tv config files.
Found it.
/User/Library/Preferences/XBMC/userdata
The Sources.xml and all the other user data xmls are in that folder.
