Full Version: [Linux] ATV1 Linux Image - enabling Composite
I am trying to install the pin87a image. I have made some changes to the xorg.conf to get video to work. So far, so good.
I am struggling to get videos to play with audio. I have menu clicks when in the menu, but all videos play without sound. I am quite sure that this is related to me using composite to connect my ATV to my television.
Any thoughts?
Hi steve,
I never tried this but I thought I would try and give you soemthing Smile
I had to change the output in the xbmc menu to plughw:0,3 like in thi guide here
http://wiki.xbmc.org/index.php?title=HOW...dio_output
You probably need to go into ssh and type the command
aplay -l
you should get the following output
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: ALC885 Analog [ALC885 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: ALC885 Digital [ALC885 Digital]
  Subdevices: 1/1
card 0: Intel [HDA Intel], device 3: ATI HDMI [ATI HDMI]
  Subdevices: 0/1
From here I think you might want to select the first two so try either plughw:0,2 or plughhw:0,1
Very newbish solution but I am wondering if it works Smile
K.
