I love the sounds of this plugin, it will be such a perfect match with Cinema Experience.
I have installed all 3 zip files, and I when I launch the plugin I get the tv/movie selection screen, but selecting one or the other does nothing.
http://pastebin.com/yqzpqr8Y
Hopefully this can help,
thanks
hi foxm2k,
No the warning is just there to tell you, that you may experience xbmc locking up completely - and that this is most likely due to a bug in xbmc, which has been fixed in Eden, but won't be fix in Dharma.
Hi bluenote,
thanks for your log. It looks like there is an error in your advancedsettings.xml. </advancedsettings> appear twice near the end, ie. the xml is not well formed.
I will try to handle such an error more gracefully.
br.
Tommy
is there any way to implement the movie quiz in cinema experience ? And if yes how ?
Greets
Eisi
Hi Eisi,
We are working on integrating it with Cinema Experience, but I haven't heard Giftie in a while. I'll check up on the progress.
br.
Tommy
sexy!
twinther
thx for the answer.
Greets
Eisi
twinther Wrote:hi foxm2k,
Your are right. It is completely freezing when entering quiz mode. So seems there is nothing I can do so far. Unfortunately...
Hi bluenote,
br.
Tommy
Thanks twinther, that helped. Great plugin, I love it! Thank you
Hi guys,
I uploaded a new version yesterday on github with Cinema Experience integration.
https://github.com/downloads/twinther/sc...-0.3.2.zip
Changelog:
- Improved support for XBMC Eden nightly builds
- Added support for Cinema Experience integration
- Use fanart instead of movie clips where relevant
- Improved data selection for some questions
- Added icons for replaying movie clip and exiting the game
- Removed 'When was episode first aired?' question as it's too difficult
- Removed French translation as it was outdated
I'm trying to get the addon added to the official repo, but for now you can install with the zip linked above.
As always let me know what you think, suggestions, complaints..
Br.
Tommy
Just installed 0.3.2 running the latest nightly build and the script fails to run, I can provide you a debug log if you'd like?
Edit: solved the issue, I was missing script.module.elementtree and script.module.myconnpy.
Hi guys,
just to let you know that the movie quiz addon is now available in the official repository.
Latest version is 0.3.2.
Br.
Tommy
Just installed the latest nightly as I couldn't get the TV quiz to work with 10.1
I've downloaded the 3.2 version from the previous page but get a "dependencies not met" issue when trying to install it.
Any ideas?
Ignore the last message. Reinstalled 10.1, installed Quiz 3.2 and all good
Yeah. I think version 0.3.2 is broken in XBMC Eden again, it is a moving target at the moment.
However I am working on a new version of the movie quiz targeted for Eden, but it's still work in progress.
The git is public though if anyone is feeling adventurous
br.
Tommy
