Does anyone know where I can get a copy of rsync that will run on the ATV2? I have surfed the web for a couple of hours looking but have no luck. Any elp would be appreciated.
Well, I have rsync in the default repos that get installed with the JB:
Quote:AppleTV:~ root# apt-cache showpkg rsync
Package: rsync
Versions:
3.0.5-3 (/var/lib/apt/lists/apt.saurik.com_dists_tangelo-3.7_main_binary-iphoneos-arm_Packages)
Description Language:
File: /var/lib/apt/lists/apt.saurik.com_dists_tangelo-3.7_main_binary-iphoneos-arm_Packages
MD5: 610cbcd450ad89fdd633a45dede6b621
Reverse Depends:
Dependencies:
3.0.5-3 - dpkg (2 1.14.25-8)
Provides:
3.0.5-3 -
Reverse Provides:
Just
Quote:apt-get install rsync
and you are done
Thanks - That worked a treat.
