Brilliant skin, just set it up and its very nice, some great fetures that might tempt me to leave Alaska Revisited
Couple things:
I spent a long time getting landscape images for seasons which work great on season level on list view, but the skin prefers posters at episode level on episode slide view. Is there a way to save a poster and a landscape season image to get around this conflict?
In the TV guide (great feature btw), when I press up I get what look like landscape/posters compressed to banners. Why doesn't it just use my banners?
My 'Episode delete' function is not available, is this not in the official repo yet?
Is there a way to change the options seen on the home menu when pressing down, on say TV or Movies? I dont use/like genres, year etc, but can't see a hide/show toggle.
Overall, very impressed, looks great on my TV, can't wait to see it on my new 50" when it arrives!!
Very good work sir.
Not sure if this is a bug, but when going into the carousel in the library for movies and tv-shows, it always lands on random shows/movies rather than the top. Is this normal behavior?
Also, as a suggestion, I am curious if you could add a slider to the side of the carousel to scroll down faster by chunks instead of one-at-a-time?
I love this skin, it's really beyond simple actually
but in a cool way.
I was wondering however, if i select 'use posters instead of banners for tv shows', the banner shows up when in the show specific menu. However when i toggle this function of (so i use banners instead of posters) it doesn't seem to pick up banner.jpg in the tv-shows overview (so the main tv-show windows). This might be due to the fact that i just starting using the skin.
Furthermore, is it possible to install this skin from a repo, so I get notified when a new version is out?
Great work, really
Love the skin so far!
Possible Bug:
I have music fanart enabled for the background of the "Music" home screen. It shows random artist pictures, as it should. But when I browse artists in Thumbnail view, it continues to show random pics rather than the artist who is highlighted.
Bug:
When choosing a screenshot folder in settings, attempt to make a new folder. When you do so, the location pane overlaps the keyboard and prevents you from being able to name folder you want to create.
I have an idea for the backgounds in this skin...so have a look on my .zip
A nice idea for the movie and series button is when the tv shows the fanart in it!? Is this doable?
http://dl.dropbox.com/u/933811/backgrounds.zip
greetings Smooth
SmoothMC Wrote:I have an idea for the backgounds in this skin...so have a look on my .zip
greetings Smooth
Can you post the images on imgur.com or send them to
[email protected]. I cant view that site at work.
Hi. Have you got planned make another views for advLauncher?
Are there any plans to implement images of the cast while in movie/tv-info screen ?
I just started adding music to XBMC and it is awesome. However I reinstall XBMC 9.11 then upgraded to 10.1 to fix a error I kept having and now Simplicity only shows wall paper for music no visualization images.
What must I enable to get that back. I love the record turntable rocks.
PS: I found it
Awesome how the music looks this is now the only skin I use.
Randall Lind Wrote:I just started adding music to XBMC and it is awesome. However I reinstall XBMC 9.11 then upgraded to 10.1 to fix a error I kept having and now Simplicity only shows wall paper for music no visualization images.
PS: I found it Awesome how the music looks this is now the only skin I use.
Glad you like it Randall. Feel free to take screenshots and post of your favorite views and options so other users can see what possibilities it holds. Some users never look deep enough into the Skin Settings section. There are lots of little tweaks and things.
otcho Wrote:Are there any plans to implement images of the cast while in movie/tv-info screen ?
What skin has this? Can you show me some screenshots? I have never seen this in a skin I've used. What has to be done to implement it?
Just Paper Street Soap Company ( isn't it? Still work in progress and I imagine might start slowing the skin down?
In my experience, Simplicity is the only skin which
doesn't have this feature. But here is a screenshot from Confluence:
In your skin, the names of the actors are already displayed. It would be cool to press the 'up' button and you could access the pictures of the cast.
I hope it's clear what my intention is
