I´m having serious problems with Dharma Live 10.0 “Dharma” and Shuttle XS35GT (ion2).
Problem is that system freezes if I surf around XBMC´s menus, listen to music or watch a HD-video. And this happens always, so XBMC is pretty much unusable because of this.
When watching SD-video system works just fine, but after coming back to menu, it freezes quite instantly. I´ve tested with different ram-modules and different HDD´s with no difference at all. A little before freeze there appears some distortion and flickering in the display. When system freezes this goes much worse. System doesn´t response to mouse or keyboard or remote. CLI trough SSH works fine.
There´s no errors in xbmc.log normally when this happens. Only when watching HD-videos. However dmesg gives always a same kind of error:
When starting music and freezing happens:
[ 42.539526] hda-intel: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj. <-- this comes when hitting play
[ 76.319169] NVRM: Xid (0001:00): 13, 0003 00000000 0000502d 000002a4 00000000 00000080
when starting hd-video and freezing happens:
[ 57.712085] hda-intel: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj. <-- this comes when hitting play
[ 93.893719] NVRM: Xid (0001:00): 30, Ch 00000008 M 0000001c D 00000001 intr 00100000
when "surfing" menus and freezing happens:
[ 184.718724] NVRM: Xid (0001:00): 13, 0003 00000000 00008597 00000f00 00003800 00000040
I´ve run memtest without error for long time, and Openelec works just fine on this system, so I think there shouldn´t be anything wrong with my hardware.
Well same here on ubuntu lucid 64-bit and mint 9 also 64-bit.
Nothing extraordinary in xbmc.log, however the /var/log/Xorg.0.log gives me that:
(II) XKB: generating xkmfile /var/lib/xkb/server-DF25F8757BF3BDBEE86E44C6BA4626168A6E8386.xkm
(II) XKB: reuse xkmfile /var/lib/xkb/server-DF25F8757BF3BDBEE86E44C6BA4626168A6E8386.xkm
(WW) Feb 01 21:12:26 NVIDIA(0): WAIT (2, 6, 0x8000, 0x0000a474, 0x0000bb7c)
(WW) Feb 01 21:12:33 NVIDIA(0): WAIT (1, 6, 0x8000, 0x0000a474, 0x0000bb7c)
(WW) Feb 01 21:45:51 NVIDIA(0): WAIT (2, 6, 0x8000, 0x00009b58, 0x0000b260)
(WW) Feb 01 21:45:55 NVIDIA(0): WAIT (0, 6, 0x8000, 0x0000b260, 0x0000b260)
I'm not quite sure if it's dharma related or x-server related. I've tested so far 3 different nvidia drivers an got always same result.
Is there any way to fix this? It makes xbmc unusable.
cheers
/aedon
What does 'cat /proc/interrupts' say?
thethirdnut Wrote:What does 'cat /proc/interrupts' say?
xbmc@XBMCLive:~$ cat /proc/interrupts
CPU0 CPU1 CPU2 CPU3
0: 49 0 0 0 IO-APIC-edge timer
1: 2 2 2 2 IO-APIC-edge i8042
8: 0 1 0 0 IO-APIC-edge rtc0
9: 3 4 4 4 IO-APIC-fasteoi acpi
12: 5 2 2 4 IO-APIC-edge i8042
16: 1681 1681 1695 1689 IO-APIC-fasteoi uhci_hcd:usb5, hda_intel, nvidia
17: 49 46 43 52 IO-APIC-fasteoi hda_intel
18: 2036 2034 2021 2047 IO-APIC-fasteoi uhci_hcd:usb4, mmc0, jmb38x_ms:slot0
19: 0 0 0 0 IO-APIC-fasteoi uhci_hcd:usb3, wlan0
23: 0 1 2 0 IO-APIC-fasteoi ehci_hcd:usb1, uhci_hcd:usb2
27: 777 794 780 781 PCI-MSI-edge ahci
28: 448 436 454 422 PCI-MSI-edge eth0
NMI: 0 0 0 0 Non-maskable interrupts
LOC: 13167 11453 9622 9540 Local timer interrupts
SPU: 0 0 0 0 Spurious interrupts
PMI: 0 0 0 0 Performance monitoring interrupts
PND: 0 0 0 0 Performance pending work
RES: 222 166 122 270 Rescheduling interrupts
CAL: 1714 3461 3408 3298 Function call interrupts
TLB: 408 264 532 764 TLB shootdowns
TRM: 0 0 0 0 Thermal event interrupts
THR: 0 0 0 0 Threshold APIC interrupts
MCE: 0 0 0 0 Machine check exceptions
MCP: 1 1 1 1 Machine check polls
ERR: 3
MIS: 0
uname -a
Linux htpc 2.6.32-21-generic #32-Ubuntu SMP Fri Apr 16 08:09:38 UTC 2010 x86_64 GNU/Linux
free -m
total used free shared buffers cached
Mem: 7499 7421 77 0 142 5734
-/+ buffers/cache: 1544 5954
Swap: 16386 0 16386
/proc/interrupts
CPU0 CPU1
0: 27 560 IO-APIC-edge timer
1: 0 4 IO-APIC-edge i8042
6: 0 2 IO-APIC-edge floppy
7: 1 0 IO-APIC-edge
8: 0 1 IO-APIC-edge rtc0
9: 0 0 IO-APIC-fasteoi acpi
12: 0 6 IO-APIC-edge i8042
17: 5854948 6683405 IO-APIC-fasteoi saa7146 (0)
20: 13310 20769 IO-APIC-fasteoi ohci_hcd:usb4, HDA Intel
21: 585171 2411396 IO-APIC-fasteoi ohci_hcd:usb3, nvidia
22: 0 2 IO-APIC-fasteoi ehci_hcd:usb2
23: 0 3 IO-APIC-fasteoi ehci_hcd:usb1
26: 5191 1521630 PCI-MSI-edge ahci
27: 53817 9862317 PCI-MSI-edge eth0
NMI: 0 0 Non-maskable interrupts
LOC: 111708932 5672708 Local timer interrupts
SPU: 0 0 Spurious interrupts
PMI: 0 0 Performance monitoring interrupts
PND: 0 0 Performance pending work
RES: 10301788 6778214 Rescheduling interrupts
CAL: 98370 154271 Function call interrupts
TLB: 26412 151550 TLB shootdowns
TRM: 0 0 Thermal event interrupts
THR: 0 0 Threshold APIC interrupts
MCE: 0 0 Machine check exceptions
MCP: 322 322 Machine check polls
ERR: 1
MIS: 0
~/.nvidia-settings-rc
# Configuration file for nvidia-settings - the NVIDIA X Server Settings utility
# Generated on Tue Feb 1 16:55:08 2011
# ConfigProperties:
RcFileLocale = C
ToolTips = Yes
DisplayStatusBar = No
SliderTextEntries = Yes
IncludeDisplayNameInConfigFile = No
ShowQuitDialog = No
Timer = PowerMizer_Monitor_(GPU_0),Yes,1000
Timer = Thermal_Monitor_(GPU_0),Yes,1000
# Attributes:
0/CursorShadow=0
0/CursorShadowAlpha=64
0/CursorShadowRed=0
0/CursorShadowGreen=0
0/CursorShadowBlue=0
0/CursorShadowXOffset=4
0/CursorShadowYOffset=2
0/SyncToVBlank=0
0/LogAniso=0
0/FSAA=0
0/TextureSharpen=0
0/AllowFlipping=1
0/FSAAAppControlled=1
0/LogAnisoAppControlled=1
0/OpenGLImageSettings=1
0/FSAAAppEnhanced=0
0/RedBrightness=0.000000
0/GreenBrightness=0.000000
0/BlueBrightness=0.000000
0/RedContrast=0.000000
0/GreenContrast=0.000000
0/BlueContrast=0.000000
0/RedGamma=1.000000
0/GreenGamma=1.000000
0/BlueGamma=1.000000
0/DigitalVibrance[DFP-0]=0
0/ImageSharpening[DFP-0]=127
0/GPUScaling[DFP-0]=131075
0/OverscanCompensation[DFP-0]=97
0/XVideoTextureBrightness=0
0/XVideoTextureContrast=0
0/XVideoTextureHue=0
0/XVideoTextureSaturation=0
0/XVideoTextureSyncToVBlank=1
0/XVideoSyncToDisplay=65536
/etc/X11/xorg.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 1.0 (buildd@yellow) Fri Apr 9 11:51:21 UTC 2010
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Toshiba"
ModelName "TSB TOSHIBA-TV"
HorizSync 15.0 - 46.0
VertRefresh 49.0 - 61.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce 8200"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "TwinView" "0"
Option "metamodes" "1360x768_60 +0+0"
SubSection "Display"
Depth 24
EndSubSection
EndSection
dont know which nvidia driver version dharma-live uses, but i know about issues with early drivers from version 260 and systems with 1GB RAM. thats why openelec has downgraded this time to version 256. this issue should be fixed with with 260.19.21 and later (
http://www.nvidia.com/object/linux-displ...river.html "Fixed a bug in VDPAU that caused it to attempt allocation of huge blocks of system memory. This regression was introduced in the 260.* driver series.")
Well dunno about Dharma Live. I'm using this one:
https://launchpad.net/~lars-opdenkamp/+a...lter=lucid on Linux Mint LTS.
I'm still using the 195.36.24 driver from the official Ubuntu restricted. The 260.xx.xx driver, however, had the same problem. Nevertheless I've just spotted the 270.18.xx in yaVDR repository. Let me test it.
dpkg -l |grep xorg
ii python-xkit 0.4.2.2 library for the manipulation of the xorg.con
ii xorg 1:7.5+5ubuntu1 X.Org X Window System
ii xorg-docs-core 1:1.5-1 Core documentation for the X.org X Window Sy
ii xserver-xorg 1:7.5+5ubuntu1 the X.Org X server
ii xserver-xorg-core 2:1.7.6-2ubuntu7 Xorg X server - core server
ii xserver-xorg-input-all 1:7.5+5ubuntu1 the X.Org X server -- input driver metapacka
ii xserver-xorg-input-evdev 1:2.3.2-5ubuntu1 X.Org X server -- evdev input driver
ii xserver-xorg-input-mouse 1:1.5.0-1 X.Org X server -- mouse input driver
ii xserver-xorg-input-synaptics 1.2.2-1ubuntu4 Synaptics TouchPad driver for X.Org server
ii xserver-xorg-input-vmmouse 1:12.6.5-4ubuntu2 X.Org X server -- VMMouse input driver to us
ii xserver-xorg-input-wacom 1:0.10.5-0ubuntu4 X.Org X server -- Wacom input driver
ii xserver-xorg-video-all 1:7.5+5ubuntu1 the X.Org X server -- output driver metapack
ii xserver-xorg-video-apm 1:1.2.2-1 X.Org X server -- APM display driver
ii xserver-xorg-video-ark 1:0.7.2-1 X.Org X server -- ark display driver
ii xserver-xorg-video-ati 1:6.13.0-1ubuntu5 X.Org X server -- AMD/ATI display driver wra
ii xserver-xorg-video-chips 1:1.2.2-1 X.Org X server -- Chips display driver
ii xserver-xorg-video-cirrus 1:1.3.2-1ubuntu1 X.Org X server -- Cirrus display driver
ii xserver-xorg-video-fbdev 1:0.4.1-1ubuntu1 X.Org X server -- fbdev display driver
ii xserver-xorg-video-i128 1:1.3.3-1 X.Org X server -- i128 display driver
ii xserver-xorg-video-intel 2:2.9.1-3ubuntu5 X.Org X server -- Intel i8xx, i9xx display d
ii xserver-xorg-video-mach64 6.8.2-2 X.Org X server -- ATI Mach64 display driver
ii xserver-xorg-video-mga 1:1.4.11.dfsg-2ubuntu1 X.Org X server -- MGA display driver
ii xserver-xorg-video-neomagic 1:1.2.4-2 X.Org X server -- Neomagic display driver
ii xserver-xorg-video-nouveau 1:0.0.15+git20100219+9b4118d-0ubuntu5 X.Org X server -- Nouveau display driver (ex
ii xserver-xorg-video-nv 1:2.1.15-1ubuntu3 X.Org X server -- NV display driver
ii xserver-xorg-video-openchrome 1:0.2.904+svn827-1 X.Org X server -- VIA display driver
ii xserver-xorg-video-r128 6.8.1-2ubuntu1 X.Org X server -- ATI r128 display driver
ii xserver-xorg-video-radeon 1:6.13.0-1ubuntu5 X.Org X server -- AMD/ATI Radeon display dri
ii xserver-xorg-video-rendition 1:4.2.3-1 X.Org X server -- Rendition display driver
ii xserver-xorg-video-s3 1:0.6.3-1 X.Org X server -- legacy S3 display driver
ii xserver-xorg-video-s3virge 1:1.10.4-1 X.Org X server -- S3 ViRGE display driver
ii xserver-xorg-video-savage 1:2.3.1-1ubuntu1 X.Org X server -- Savage display driver
ii xserver-xorg-video-siliconmotion 1:1.7.3-1 X.Org X server -- SiliconMotion display driv
ii xserver-xorg-video-sis 1:0.10.2-2 X.Org X server -- SiS display driver
ii xserver-xorg-video-sisusb 1:0.9.3-1 X.Org X server -- SiS USB display driver
ii xserver-xorg-video-tdfx 1:1.4.3-1 X.Org X server -- tdfx display driver
ii xserver-xorg-video-trident 1:1.3.3-1 X.Org X server -- Trident display driver
ii xserver-xorg-video-tseng 1:1.2.3-1 X.Org X server -- Tseng display driver
ii xserver-xorg-video-v4l 1:0.2.0-4 X.Org X server -- Video 4 Linux display driv
ii xserver-xorg-video-vesa 1:2.3.0-1ubuntu1 X.Org X server -- VESA display driver
ii xserver-xorg-video-vmware 1:10.16.9-1 X.Org X server -- VMware display driver
ii xserver-xorg-video-voodoo 1:1.2.3-1 X.Org X server -- Voodoo display driver
So after installing 270.18 nvidia driver i get following:
/var/log/Xorg.0.log
(II) XKB: reuse xkmfile /var/lib/xkb/server-9444312A1B7871FCD45C1129E5151AB3EAFC6D4F.xkm
(WW) Feb 03 00:10:12 NVIDIA(0): WAIT (2, 6, 0x8000, 0x0000ea14, 0x00000570)
(WW) Feb 03 00:10:17 NVIDIA(0): WAIT (0, 6, 0x8000, 0x00000570, 0x00000570)
~/.xbmc/temp/xbmc.log
00:10:14 T:140218029192960 M:6624772096 DEBUG: CDVDPlayerAudio:: Discontinuity - was:4651645736.190201, should be:4651974540.310912, error:328804.120711
00:10:15 T:140218029192960 M:6624772096 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
00:10:21 T:140218037585664 M:6678482944 ERROR: VDPAU Device Preempted - attempting recovery
00:10:21 T:140218037585664 M:6678482944 ERROR: (VDPAU) Error: The display was pre-empted, or a fatal error occurred.(2) at VDPAU.cpp:1122
00:10:21 T:140218037585664 M:6678482944 NOTICE: Attempting recovery
00:10:21 T:140218037585664 M:6678482944 NOTICE: (VDPAU) FiniVDPAUOutput
00:10:22 T:140218037585664 M:6678450176 NOTICE: vdp_device = 0x00000001 vdp_st = 0x00000000
00:10:22 T:140218037585664 M:6678450176 DEBUG: CDVDPlayerVideo - video decoder was flushed
Then XBMC is gone and takes X-Servver with it. The only thing I can do is to reboot the system via ssh.
Any ideas?
Cheers
/aedon
Do you have adjust refreshrate turned on? There's a problem with that on 64 bit nvidia systems.
Indeed, I did, however it was not the problem. I found out that strange behavior was caused by a mismatched BIOS of my Asus M3N78-VM (nvidia 8200 on-board). I even had some issues on erasing blocks while re-flashing the BIOS. XBMC is rock stable since yesterday. Thank you all for your input!
Cheers
/aedon
No vertical blank sync on.
Just tested with 2GB RAM, still freezing.
I´ve tested hardware now with Win7 and XBMC. There´s no freezing, only some pixelation on videos on start and after pausing.
Can it still be a hardware-issue, or is there something wrong with XBMC Live tha causes my system to freeze?
I´m getting very tired with this problem. Easy way would be to send the machine to Shuttle for check up, but I have to pay for shipping if there´s nothing wrong with hardware.
