Full Version: Failure custom menu.
using the function: lists - favorite - main menu.
Playlists begin playing automatically.
file "guisettings.xml"
wrong code:
<setting type="string" name="skin.transparency.menu_custom1_path">PlayMedia(special://profile/playlists/video/Hd.xsp,return)</setting>
Corrected code to display the videos:
<setting type="string" name="skin.transparency.menu_custom1_path">ActivateWindow(10025,special://profile/playlists/video/Hd.xsp,return)</setting>
toggle this setting before adding the playlist to the submenu:
Settings > Skin Settings > Home > Play playlists in submenus
Thanks. works perfect.
This plays the first item in the playlist, it's not like opening favourites and seeing the playlist items. Has the code to open a new window changed.. I'm trying to get smart playlists in the menu and act as they do when you click a video smartplaylist in T!
PatK Wrote:This plays the first item in the playlist, it's not like opening favourites and seeing the playlist items. Has the code to open a new window changed.. I'm trying to get smart playlists in the menu and act as they do when you click a video smartplaylist in T!
Skin Settings > Home Window > Play playlists in submenus
make sure that settings is correct before you map the playlist to the submenu
ronie Wrote:Skin Settings > Home Window > Play playlists in submenus
Shoot... I've been mapping the playlist menu item to favourites instead of directly...
Still just plays the first one in the list though.. if I open under folder I get the list without graphics.
Under favourites the playlist is fine, just don't know how to map it to the menu so that it opens the same.
